68 B-body 4-spd backup light switch harness routing #68491
06/06/08 05:59 AM
06/06/08 05:59 AM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
I bought a new reproduction backup light switch harnesss that goes from the switch on the transmission to the bulkhead connector and I need to know how it was routed from the factory. I know there were some of those rubber coated metal finger type clips, but I don't know how many and where they were bolted on. Thanks
Re: 68 B-body 4-spd backup light switch harness routing [Re: Dennis_K] #68492
06/06/08 09:33 AM
06/06/08 09:33 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
What car? Console or no?
Re: 68 B-body 4-spd backup light switch harness routing [Re: 68CoronetRT] #68493
06/06/08 10:02 AM
06/06/08 10:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats doesn't matter , the harness is in the engine compartment .
Re: 68 B-body 4-spd backup light switch harness routing [Re: Dennis_K] #68494
06/06/08 10:29 AM
06/06/08 10:29 AM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
Is this what you are referring to (attached)?
Did they ever use routing clips on the bellhousing?
Re: 68 B-body 4-spd backup light switch harness routing [Re: northcoastmopar] #68495
06/06/08 11:40 AM
06/06/08 11:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
none i have ever seen
Re: 68 B-body 4-spd backup light switch harness routing [Re: northcoastmopar] #68496
06/06/08 08:18 PM
06/06/08 08:18 PM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
Those are the clips I was asking about. Brewer's website says that 2 are used, but I wasn't sure where. If that is the only place where the clips are located, it seems to me there would be a lot of wire left unsupported. I'll try to figure out a way to route the harness in a way that is better than what the factory did.
Re: 68 B-body 4-spd backup light switch harness routing [Re: Dennis_K] #68497
06/07/08 09:16 AM
06/07/08 09:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes alot of wire is left unsupported , hasn't been an issue yet
Re: 68 B-body 4-spd backup light switch harness routing [Re: JohnRR] #68498
06/08/08 10:56 AM
06/08/08 10:56 AM
California
70SportSatellite Offline
super street
super street
California
After the harness is secured to the trans it drapes over the trans, up to the passenger side upper bellhousing bolt where there is another clip. The one in the picture is incorrect. As far as I know this one is not being reproduced, I was able to find an original still intact which I installed after the picture. Then it is supported by the 3 clips on the firewal over to the bulkhead connector. I also thought there were only 2 clips on the trans of the "finger" type at positions 9 and 10. Hope this helps.
Re: 68 B-body 4-spd backup light switch harness routing [Re: 70SportSatellite] #68499
06/08/08 11:29 AM
06/08/08 11:29 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
This is a 1969 23-spline out of an original owner Bee with console, it was only out of the car in '69 for a new clutch. I'm rebuilding it for him, so I assume the clips are in the original location.
