Re: 5.7 hemi, what size flywheel bolts?
[Re: dirt]
#684846
04/30/10 06:44 PM
04/30/10 06:44 PM
Posts: 75 Lakeland, FL
sixpakchallenger
Lakeland, FL
I used:
06504398, M10x1.0x26.0 Bolt
get them from the dealer
[Re: sixpakchallenger]
#684847
04/30/10 06:58 PM
04/30/10 06:58 PM
sixpakchallenger
Lakeland, FL
Actually it's 6504398 (drop the 0) they run about $1.75 ea.
Also the pilot bearing mounts to the crank register like the 5.2/5.9 magnums (it's the same part) if that helps you find a bearing. I'm using a 833OD with my 04 5.7 hemi.
2007 Mustang GT Vert 2004 Ram 2500 QC 4X4 1971 Challenger Vert 5.7 Hemi Project
[Re: dirt]
#684849
05/01/10 10:42 AM
05/01/10 10:42 AM
Posts: 375 Canada
DmanSRT71
Canada
How does the hole in your floor look after the cuts? How did you reinforce the torsion bar cross member? Sounds like a nice setup. thanks Darren Quote:
i have a 2003 5.7 hemi that i am putting a T56 6 speed behind. i have a 130 tooth flywheel and need the bolts. i cant find anywhere that sells them for a hemi or any place that says what size they are. i believe they are metric. also i need a pilot bushing to fit the hemi and the T56. the hole in the hemi crank is 1" and the shaft on the T56 is small , like .600 i believe. i was thinking of having a machine shop make one if i cant find one to work.
thanks!
69 Road Runner 383/auto/N96
71 Demon 340/4 spd
Would like to find a rust free Cuda body.
[Re: dirt]
#684850
05/01/10 11:10 AM
05/01/10 11:10 AM
sixpakchallenger
Lakeland, FL
Mustang 4.6L ones are very close, only slightly longer. They should work.
#684851
05/01/10 06:31 PM
05/01/10 06:31 PM
Posts: 301 wisconsin
swifter
wisconsin
Got mine from TR Waters here on moparts they were APR bolts
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
