Tubes or no tubes? #684205
04/30/10 03:07 AM
04/30/10 03:07 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
What I would like to know is if anybody knows for sure what effect adding tubes or removing them has on reaction time? I need to slow my reaction time down a bit. I have everything turned down as much as I dare, launch RPM, tire pressure, etc. I shallow stage and have the biggest front tires I can get in there. I'm wondering if adding tubes might slow them down? Thanks.
Post deleted by Defbob [Re: 10sec440] #684206
04/30/10 03:34 AM
04/30/10 03:34 AM
Re: Tubes or no tubes? #684207
04/30/10 04:49 AM
04/30/10 04:49 AM
Arizona
Chris'sBarracuda Offline
Arizona
Tubes make reaction time quicker. Makes sidewall stiffer..
Less air pressure will slow reaction along with front end travel..
You can also put a stop on it and leave closed..
Chris..
Re: Tubes or no tubes? [Re: 10sec440] #684208
04/30/10 05:22 AM
04/30/10 05:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You can add air pressure to the rear tires to get
a CONTROLLED amount of slippage... once you find the
proper pressure a 1/4# means a fair amount... and I'm
sure you already lowered the front tire pressure to
help slow it in the beams
Re: Tubes or no tubes? [Re: 10sec440] #684209
05/01/10 02:01 AM
05/01/10 02:01 AM
How about stiffening up the front shocks
