Changed from 5.14 to 3.50 #684051
04/29/10 11:15 PM
04/29/10 11:15 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I have a 360/380 hp crate engine in my D-50 truck. I was running 5.14 gears and my best E.T. in the 1/8 was a 7.46 @ 91 mph. I shift at 5600 rpm. Last weekend I put 3.50 gears in it. I went to T&T tonight and run it. How much do you think it slowed down ? I crossed the finish line in 2nd gear.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Post deleted by Defbob [Re: D-50] #684052
04/29/10 11:19 PM
04/29/10 11:19 PM
Re: Changed from 5.14 to 3.50 #684053
04/29/10 11:22 PM
04/29/10 11:22 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
2 tenths
Re: Changed from 5.14 to 3.50 [Re: D-50] #684054
04/29/10 11:39 PM
04/29/10 11:39 PM
Not much,(at tenth or two max) especailly if your spinning the tires with the 5:14 gears
Re: Changed from 5.14 to 3.50 [Re: D-50] #684055
04/29/10 11:56 PM
04/29/10 11:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You may of increased your ET. 5.14 gears are pretty steep, and can make that first gear pretty useless depending on tire size and tranny gear.
You know this allready, I can tell.
Your first gear is your Best accelerating gear.
With a switch in axel gearing even a second gear tranny combo can equal a first gear tranny combination for a equal gear multiplication. mike
Post deleted by Defbob [Re: Sport440] #684056
04/30/10 12:25 AM
04/30/10 12:25 AM
Re: Changed from 5.14 to 3.50 #684057
04/30/10 02:05 AM
04/30/10 02:05 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Maybe .08
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Changed from 5.14 to 3.50 [Re: D-50] #684058
04/30/10 07:59 AM
04/30/10 07:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
4 tenths and 2 mph
Re: Changed from 5.14 to 3.50 [Re: D-50] #684059
04/30/10 10:22 AM
04/30/10 10:22 AM
NC
chris3 Offline
chris3  Offline
NC
I'm waiting for you to tell me the results. I have just changed from 513 to 488. How much does your truck weigh? What trans?
Post deleted by Defbob [Re: chris3] #684060
04/30/10 10:49 AM
04/30/10 10:49 AM
Re: Changed from 5.14 to 3.50 [Re: D-50] #684061
04/30/10 02:52 PM
04/30/10 02:52 PM
houston texas
gremlinsteve Offline
houston texas
ill guess...7.80's
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Changed from 5.14 to 3.50 [Re: D-50] #684062
04/30/10 03:54 PM
04/30/10 03:54 PM
Okay, time for the results
Re: Changed from 5.14 to 3.50 [Re: Cab_Burge] #684063
04/30/10 04:27 PM
04/30/10 04:27 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I think it didnt slow down, it went faster....Phill
Re: Changed from 5.14 to 3.50 #684064
04/30/10 05:29 PM
04/30/10 05:29 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
not to hijack Glenns thread, but a buddy went from 4.56 to 5.38s and picked up 4 tenths. 7.80s to 7.40s in the 1/8. heavy car small motor.
Re: Changed from 5.14 to 3.50 [Re: sixpackgut] #684065
04/30/10 06:13 PM
04/30/10 06:13 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
My best ET with the 5.14 was 1.54 60 ft. 7.46 @ 91 mph crossing the finish line at about 6000 rpm in high gear. It has a 904 trans. Last night with the 3.50 gears I had a best of 1.65 60ft., 7.66 @ 90mph crossing the stripe in 2nd gear. It has 315/60 15 M/T drag radials on it.
Post deleted by Defbob [Re: sixpackgut] #684066
04/30/10 06:19 PM
04/30/10 06:19 PM
Re: Changed from 5.14 to 3.50 [Re: D-50] #684067
04/30/10 06:23 PM
04/30/10 06:23 PM
organ
maximum entropy Offline
organ
i bet with a different converter you could get your .2 back.
Re: Changed from 5.14 to 3.50 #684068
04/30/10 06:31 PM
04/30/10 06:31 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
The first pass I made it felt so sick I thought I had it second gear. I also tried something else last night I put my old NOS plate on this week and sprayed it with 47 fuel/53 n2o jets suppose to be 100 shot.
Re: Changed from 5.14 to 3.50 [Re: D-50] #684069
04/30/10 08:36 PM
04/30/10 08:36 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Forgot to tell what it ran on 100 shot, 7.14@95mph, 1.53 60 ft.Thinking about trying 125 next.
Re: Changed from 5.14 to 3.50 [Re: D-50] #684070
04/30/10 10:24 PM
04/30/10 10:24 PM
Alabama
cj38 Offline
cj38  Offline
Alabama
I was surprised it did'nt loose more et. I was expecting 7.80's/7.90's.
