3rd shift #683995
04/29/10 10:27 PM
04/29/10 10:27 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Got my trans back from the shop..
But it won't shift into 3rd gear !!
What could be ??
It's a A-999 trans 1987
Dan
Re: 3rd shift [Re: Wedgeman] #683996
04/30/10 12:48 AM
04/30/10 12:48 AM
KD linkage is correct?
Re: 3rd shift [Re: Wedgeman] #683997
04/30/10 01:21 AM
04/30/10 01:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've had a few automatics over the years that took awhile to shift into 3rd gear. The 904 in my 67 Dart shifts great, but when it is cold and warming up, it takes longer to upshift and the road speed is higher. Once it is up to temp, it shifts normally.
Re: 3rd shift [Re: Kern Dog] #683998
04/30/10 08:50 AM
04/30/10 08:50 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I double checked the linkage and after hours of driving it still doesn't shift..
Dan
Re: 3rd shift [Re: Wedgeman] #683999
04/30/10 09:51 AM
04/30/10 09:51 AM
Andrewh Offline
Andrewh  Offline
could the shifter linkage be off?
did you see if you have another space to move it, like between neutral and drive?
Re: 3rd shift [Re: Kern Dog] #684000
04/30/10 11:00 AM
04/30/10 11:00 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I have the same issue with a fresh 1965 727. It takes forever to shift into 3rd when cold. Once up to 30mph or so, I can shift to neutral and back to drive and it goes right into 3rd. The problem is not as bad when the trans warms up. Had the pan off to assure that the shift linkage was perfectly adjusted and the kickdown is a new Bouchillon adjusted properly. I am leaning toward a valve body issue.
This is the land of the free because of the brave
Re: 3rd shift [Re: Andrewh] #684001
04/30/10 11:50 AM
04/30/10 11:50 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Andrew.......please !!!!!!!! loll
Re: 3rd shift [Re: Wedgeman] #684002
04/30/10 11:59 AM
04/30/10 11:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
So it has 1st 2nd then stays in second no matter where the shifter???
Could be valve body I once but a ball in the wrong spot and it had 1st 2nd and still second but that was a manual VB>
Re: 3rd shift [Re: Dodgem] #684003
04/30/10 01:20 PM
04/30/10 01:20 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Exactly....stays in 2nd no matter what
Re: 3rd shift [Re: Wedgeman] #684004
04/30/10 01:31 PM
04/30/10 01:31 PM
Andrewh Offline
Andrewh  Offline
No seriously, if your shifter is off, you could be in 2nd not D. So you never go into third.
Now if it goes into third after it is warmed up, then I don't know what I am talking about.
Re: 3rd shift [Re: Wedgeman] #684005
04/30/10 01:39 PM
04/30/10 01:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
First thing to do is disconnect the throttle pressure linkage at the transmission lever and allow the lever to go full forward, if it will shift to 3rd with the linkage off the linkage is the problem. If it still won't shift the problem is internal.
Re: 3rd shift [Re: John_Kunkel] #684006
04/30/10 02:32 PM
04/30/10 02:32 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok I will try that John
Re: 3rd shift [Re: Wedgeman] #684007
04/30/10 07:44 PM
04/30/10 07:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
No difference John........eve shifts to 2nd earlier.....
Dan
Re: 3rd shift [Re: Wedgeman] #684008
04/30/10 07:46 PM
04/30/10 07:46 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Drop the pan and make sure the valve body bolts are tight. Then check the band adjustment while you are in there...
Re: 3rd shift [Re: Wedgeman] #684009
05/01/10 04:32 PM
05/01/10 04:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As mentioned earlier, if the large check ball is left out of the valve body there will be no 2-3 shift.
Re: 3rd shift [Re: John_Kunkel] #684010
05/01/10 05:26 PM
05/01/10 05:26 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Where can I get a diagram of the body and location of the famous checkball ??
Dan
Re: 3rd shift [Re: Wedgeman] #684011
05/02/10 02:49 AM
05/02/10 02:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
this shows the big ball in a manual but I think there are less balls in a auto VB but the big ball goes the same place.
Re: 3rd shift [Re: Dodgem] #684012
05/02/10 02:50 AM
05/02/10 02:50 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
another
Re: 3rd shift [Re: Dodgem] #684013
05/02/10 02:51 AM
05/02/10 02:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
lower.
Re: 3rd shift [Re: Dodgem] #684014
05/02/10 11:13 AM
05/02/10 11:13 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I got the sportsman Valve body from SMR transmissions, it is a muanual vb with full automatic is left in drive
