Re: 3rd shift
[Re: Kern Dog]
#684000
04/30/10 11:00 AM
04/30/10 11:00 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I have the same issue with a fresh 1965 727. It takes forever to shift into 3rd when cold. Once up to 30mph or so, I can shift to neutral and back to drive and it goes right into 3rd. The problem is not as bad when the trans warms up. Had the pan off to assure that the shift linkage was perfectly adjusted and the kickdown is a new Bouchillon adjusted properly. I am leaning toward a valve body issue.
This is the land of the free
because of the brave
Re: 3rd shift
[Re: Wedgeman]
#684004
04/30/10 01:31 PM
04/30/10 01:31 PM
Andrewh
could the shifter linkage be off? did you see if you have another space to move it, like between neutral and drive?
Andrew.......please !!!!!!!! loll
No seriously, if your shifter is off, you could be in 2nd not D. So you never go into third. Now if it goes into third after it is warmed up, then I don't know what I am talking about.
Re: 3rd shift
[Re: Wedgeman]
#684005
04/30/10 01:39 PM
04/30/10 01:39 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First thing to do is disconnect the throttle pressure linkage at the transmission lever and allow the lever to go full forward, if it will shift to 3rd with the linkage off the linkage is the problem. If it still won't shift the problem is internal.
Re: 3rd shift
[Re: Wedgeman]
#684009
05/01/10 04:32 PM
05/01/10 04:32 PM
John_Kunkel
Rio Linda, CA
As mentioned earlier, if the large check ball is left out of the valve body there will be no 2-3 shift.
Re: 3rd shift
[Re: Dodgem]
#684014
05/02/10 11:13 AM
05/02/10 11:13 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
So it has 1st 2nd then stays in second no matter where the shifter???
Could be valve body I once but a ball in the wrong spot and it had 1st 2nd and still second but that was a manual VB>
I got the sportsman Valve body from SMR transmissions, it is a muanual vb with full automatic is left in drive
