Re: Carb recomendation
[Re: moparmatt383]
#68374
06/06/08 09:12 AM
06/06/08 09:12 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
If I were you I would register at hotrodders.com, and find a guy named "Tech @ BG" -- he is a helpful guy and will recommend a carb for you. The phone service at BG is notoriously lousy and rude, but this guy is an exception but I don't know his phone #. For my , with that cam it calls for the mighty demon, and the smallest one they make which is 650 CFM. They flow more than that. For my 440 they recommended the 750 CFM mighty demon, OR the 800 CFM annular discharge since some of the flow is restricted by the larger boosters. I went with the annular, and after 45 minutes taking the carb apart, finishing up the drilling they didn't complete (partially drilled holes in metering blocks), removing small flakes of metal that were hanging ready to come off (in metering blocks and body), then blowing the whole thing out, I'm happy with how it runs. Count on taking it apart and going through it.. BGs reputation for bad QC is deserved (my carb was bought new a couple months ago, so the QC problems still exist).
[Re: Exit1965]
#68375
06/06/08 03:43 PM
06/06/08 03:43 PM
Posts: 3,329 Melbourne, FL
dwbiggs
super gas
super gas
Melbourne, FL
Thats pretty amazing...I started hearing about their quality issues years ago, you would have thought they would have them under control by now.
[Re: dwbiggs]
#68376
06/06/08 04:03 PM
06/06/08 04:03 PM
Exit1965
Rancho Cordova, CA
Yeah, I would have thought so too. At least mine wasn't full of metal shavings as they used to be famous for. Perhaps they are getting better, at least washing the shavings out now, just not bothering to remove hanging metal slivers or drill holes completely.
[Re: Exit1965]
#68377
06/06/08 04:52 PM
06/06/08 04:52 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I went through 2 Holley carbs (one 870 Street Avenger and one 3310 750). I'm pretty carb savvy, but I could not get either of these to work properly. I've always sworn by Holley's and I'm sure the HP carbs are excellent as are the double pumpers. I tried to find one in stock, but all anyone had was a BG speed Demon 750. I've heard so much about the problems with these carbs, but I was desperate.
I've got to admit, it does work awesome. I had to open the idle feed restrictor up a couple of thou to get rid of a lean surge at cruise speeds, but it is really responsive and has some nice features. Just my
[Re: torkrules]
#68378
06/06/08 08:21 PM
06/06/08 08:21 PM
Posts: 3,312 Marine Corps Base Hawaii
DemonKyle
USMC LCPL
USMC LCPL
Demon carbs, when drilled right and not full of shavings, run awesome. Having said that, I am proud to have a Holley 750dp on my car after my own problems with BG carbs causing it to break engine parts. Just know that Demon carbs are underrated about 70-80 cfm. So a 650 mighty demon will actually flow about 720 which in my opinion should run amazingly on your car
[Re: DemonKyle]
#68379
06/06/08 08:32 PM
06/06/08 08:32 PM
Posts: 1,261 ILL
mark7171
ILL
demon carbs are great, they can do what a holley can do. same weakness in the secondaries, you have to keep it pulling the secondary's fuel, otherwise it gets flat.
that edelbrock has a rod spring thing you get right and it works fine. the mechanical nature of the secondaries is a big plus. its also underated 50 cfm or so, actaully the performer flows closer to 650cfm. if you want to unload the edelbrock let me know? a guy accross the way has a 73 GTO. he wants me to rebuild a carb for him. let me know, PM me.
i cant recommend anything that you have to drill to work on your application. a demon is expensive too.
[Re: moparmatt383]
#68388
06/17/08 06:10 PM
06/17/08 06:10 PM
DemonKyle
USMC LCPL
USMC LCPL
Ah so many options! Some people that I talk to locally swear by demons so that is why I was leaning in that direction but I am not dead set on one. For my car would you recomend mechanical or vacuum seconderies? Also is a demon mech secondary carb the same thing as a holley double pumper?
Matt
Heres the difference between vac. sec. and mech. sec. as I was told by an old racer friend...
Vacuum Secondary= Gas Mileage, moderate performance.
Mechanical Secondary=Performance, moderate gas mileage.
If you want the performance when you hit the throttle, go with a double pumper. If you want gas mileage, go with a vacuum secondary.
The demon mechanical sec is just like a dp. Like stated above, a 650 mighty demon mech. sec. will work amazingly on your car. Just clean the **** out of it first
[Re: mark7171]
#68389
06/17/08 06:55 PM
06/17/08 06:55 PM
but thermoquads arent cool...
niether are you.
anyways,
I'd go TQ. BUT if you don't wanna use a spreadbore intake/adaptors.. go 700+cfm holley DP. 4-speeds LOVE DP carbs. BARRY GRANT carbs just plain SUCK.
