Carb recomendation #68372
06/06/08 01:27 AM
06/06/08 01:27 AM
New York
moparmatt383 Offline OP
New York
Hello,
I have a 73 Cuda and was wondering if you guys had some imput on a carb. Here is my set up:
340
KB Pistons
Edelbrock performer RPM cam
Ported J heads with 202 valves
Edelbrock Air Gap RPM intake
Chrome iginition box
Hooker super comp headers
4 spd
3.55 rear end.
I currently have a 600 edelbrock performer carb and I want to go to a demon.
Any thoughts on which demon? This is a street car.
Matt
Re: Carb recomendation [Re: moparmatt383] #68373
06/06/08 06:27 AM
06/06/08 06:27 AM
Central NC
gch Offline
gch  Offline
Central NC
sounds like a pretty good setup in a cool car.
I never had much luck with tuning my demon.I have always had good luck with holleys.
I think a 650 or 700 would work well.You can pick up some pretty good deals in the swap meet section.
Re: Carb recomendation [Re: moparmatt383] #68374
06/06/08 09:12 AM
06/06/08 09:12 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
If I were you I would register at hotrodders.com, and find a guy named "Tech @ BG" -- he is a helpful guy and will recommend a carb for you. The phone service at BG is notoriously lousy and rude, but this guy is an exception but I don't know his phone #.
For my , with that cam it calls for the mighty demon, and the smallest one they make which is 650 CFM. They flow more than that. For my 440 they recommended the 750 CFM mighty demon, OR the 800 CFM annular discharge since some of the flow is restricted by the larger boosters. I went with the annular, and after 45 minutes taking the carb apart, finishing up the drilling they didn't complete (partially drilled holes in metering blocks), removing small flakes of metal that were hanging ready to come off (in metering blocks and body), then blowing the whole thing out, I'm happy with how it runs.
Count on taking it apart and going through it.. BGs reputation for bad QC is deserved (my carb was bought new a couple months ago, so the QC problems still exist).
Re: Carb recomendation [Re: Exit1965] #68375
06/06/08 03:43 PM
06/06/08 03:43 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Thats pretty amazing...I started hearing about their quality issues years ago, you would have thought they would have them under control by now.
Re: Carb recomendation [Re: dwbiggs] #68376
06/06/08 04:03 PM
06/06/08 04:03 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Yeah, I would have thought so too. At least mine wasn't full of metal shavings as they used to be famous for. Perhaps they are getting better, at least washing the shavings out now, just not bothering to remove hanging metal slivers or drill holes completely.
Re: Carb recomendation [Re: Exit1965] #68377
06/06/08 04:52 PM
06/06/08 04:52 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I went through 2 Holley carbs (one 870 Street Avenger and one 3310 750). I'm pretty carb savvy, but I could not get either of these to work properly. I've always sworn by Holley's and I'm sure the HP carbs are excellent as are the double pumpers. I tried to find one in stock, but all anyone had was a BG speed Demon 750. I've heard so much about the problems with these carbs, but I was desperate.
I've got to admit, it does work awesome. I had to open the idle feed restrictor up a couple of thou to get rid of a lean surge at cruise speeds, but it is really responsive and has some nice features. Just my
Re: Carb recomendation [Re: torkrules] #68378
06/06/08 08:21 PM
06/06/08 08:21 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Demon carbs, when drilled right and not full of shavings, run awesome.
Having said that, I am proud to have a Holley 750dp on my car after my own problems with BG carbs causing it to break engine parts.
Just know that Demon carbs are underrated about 70-80 cfm. So a 650 mighty demon will actually flow about 720 which in my opinion should run amazingly on your car
Re: Carb recomendation [Re: DemonKyle] #68379
06/06/08 08:32 PM
06/06/08 08:32 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
demon carbs are great, they can do what a holley can do. same weakness in the secondaries, you have to keep it pulling the secondary's fuel, otherwise it gets flat.
that edelbrock has a rod spring thing you get right and it works fine. the mechanical nature of the secondaries is a big plus. its also underated 50 cfm or so, actaully the performer flows closer to 650cfm. if you want to unload the edelbrock let me know? a guy accross the way has a 73 GTO. he wants me to rebuild a carb for him. let me know, PM me.
i cant recommend anything that you have to drill to work on your application. a demon is expensive too.
Re: Carb recomendation [Re: mark7171] #68380
06/07/08 07:22 AM
06/07/08 07:22 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Have you thought about a Thermoquad carb? I use a chokeless 850cfm TQ carb on my built 340 Duster. The difference in the topend is fantastic compared to a 600-650cfm carb.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Carb recomendation [Re: MY340] #68381
06/07/08 09:01 AM
06/07/08 09:01 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
but thermoquads arent cool.
how about a carter AVS?
Re: Carb recomendation [Re: moparmatt383] #68382
06/07/08 12:14 PM
06/07/08 12:14 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
650 CFM would be best
Re: Carb recomendation [Re: terzmo] #68383
06/08/08 10:54 AM
06/08/08 10:54 AM
New York
New York
Ah so many options! Some people that I talk to locally swear by demons so that is why I was leaning in that direction but I am not dead set on one. For my car would you recomend mechanical or vacuum seconderies? Also is a demon mech secondary carb the same thing as a holley double pumper?
Matt
Re: Carb recomendation [Re: moparmatt383] #68384
06/08/08 09:13 PM
06/08/08 09:13 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
for your application a 650dp Speed demon should do the trick nicely.
Re: Carb recomendation [Re: JUST_N_TIME] #68385
06/09/08 01:39 AM
06/09/08 01:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check out the proform 750 vacuum secondary.
These are actually pretty nice and reasonably priced.
http://store.summitracing.com/partdetail...mp;autoview=sku
Re: Carb recomendation [Re: mark7171] #68386
06/09/08 11:46 AM
06/09/08 11:46 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
See sig line...........you're behind the times
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Carb recomendation [Re: Rug_Trucker] #68387
06/17/08 06:03 PM
06/17/08 06:03 PM
New York
New York
Another question. Are the demons that say they are mechanical secondaries the same as a holley double pumper where all 4 brl are opening all the time?
Re: Carb recomendation [Re: moparmatt383] #68388
06/17/08 06:10 PM
06/17/08 06:10 PM
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Matt
Heres the difference between vac. sec. and mech. sec. as I was told by an old racer friend...
Vacuum Secondary= Gas Mileage, moderate performance.
Mechanical Secondary=Performance, moderate gas mileage.
If you want the performance when you hit the throttle, go with a double pumper. If you want gas mileage, go with a vacuum secondary.
The demon mechanical sec is just like a dp. Like stated above, a 650 mighty demon mech. sec. will work amazingly on your car. Just clean the **** out of it first
Re: Carb recomendation [Re: mark7171] #68389
06/17/08 06:55 PM
06/17/08 06:55 PM
but thermoquads arent cool...
niether are you.
anyways,
I'd go TQ. BUT if you don't wanna use a spreadbore intake/adaptors..
go 700+cfm holley DP. 4-speeds LOVE DP carbs. BARRY GRANT carbs just plain SUCK.
