Low compression big block initial timing...? #683783
04/29/10 06:25 PM
04/29/10 06:25 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
What is a good baseline to start at with a low compression late 70s 440 as far as initial advance goes. I've currently got mine set up at around 10* BTDC, but it seems to idle better and have higher vacuum at around 14-16*. Is this suitable?
Re: Low compression big block initial timing...? [Re: Pat_Whalen] #683784
04/29/10 06:32 PM
04/29/10 06:32 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
That is fine. Give it all it will take with out pinging.
Re: Low compression big block initial timing...? [Re: Dougsmopars] #683785
04/29/10 06:35 PM
04/29/10 06:35 PM
hooziewhatsit Offline
yep, just keep an eye on the total to make sure it doesn't go too high.
Saw something about rotating the dist until you get the highest vacuum reading, then backing it off enough to lower it 1". In theory you should end up around 15ish.
Re: Low compression big block initial timing...? [Re: hooziewhatsit] #683786
04/29/10 06:46 PM
04/29/10 06:46 PM
and when you get the initial right you will most likely have to shorten the slots to stay @36-38 total (vac adv disconnected/plugged) though some people have had good luck w low compression BB's w ~40 ish expecially 383's.
Re: Low compression big block initial timing...? [Re: RapidRobert] #683787
04/29/10 08:38 PM
04/29/10 08:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
don't know about the backing it off thing, I thought you advanced it to max vacuum, then set your idle speed where you want it, and start over...back and forth, back and forth,
**Photobucket sucks**
Re: Low compression big block initial timing...? [Re: 70Cuda383] #683788
04/30/10 11:17 AM
04/30/10 11:17 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Go with as much advance as it'll take and still allow the starter to turn the motor over when hot. You may have to shorten your advance slots, or you'll over-advance the total timing. But this would be a good opportunity to put a new advance spring in there anyway. Trust me the effort is worth it, especially on a low-comp smogger 440, it really helps wake them up in terms of driveability.
