Re: Low compression big block initial timing...?
[Re: Dougsmopars]
#683785
04/29/10 06:35 PM
04/29/10 06:35 PM
Posts: 3,933 Oregon
hooziewhatsit
yep, just keep an eye on the total to make sure it doesn't go too high.
Saw something about rotating the dist until you get the highest vacuum reading, then backing it off enough to lower it 1". In theory you should end up around 15ish.
[Re: RapidRobert]
#683787
04/29/10 08:38 PM
04/29/10 08:38 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
don't know about the backing it off thing, I thought you advanced it to max vacuum, then set your idle speed where you want it, and start over...back and forth, back and forth,
**Photobucket sucks**
