Crossover blockoff #683532
04/29/10 10:04 AM
04/29/10 10:04 AM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
I just got a MP bathtub gasket (stamped Fel-Pro btw ). It comes with 2 plates to block the heat crossover. How do you attach them? RTV?
Also, coating both sides with gasgacinch, good idea?
Re: Crossover blockoff [Re: JM67RT] #683533
04/29/10 11:32 AM
04/29/10 11:32 AM
Arkansas
beatupcuda Offline
beatupcuda  Offline
Arkansas
I would think the gasgac would work everywhere.
68 Hemi 4 speed Cuda,,,,building ?
Re: Crossover blockoff [Re: beatupcuda] #683534
04/29/10 11:49 AM
04/29/10 11:49 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I would not use the plates to block the crossover. Summit sells a gasket that has it blocked already.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Crossover blockoff [Re: Prodart440] #683535
04/29/10 02:19 PM
04/29/10 02:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree.Get the one thats solid.I never liked the one with the little plates.Rocky
Chrysler Firepower
Re: Crossover blockoff [Re: therocks] #683536
04/30/10 06:21 AM
04/30/10 06:21 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
The Fel-Pro (1215 i believe) is a one-piece tin pan thats blocked off too. Thats what i've always used. Too easy.
Re: Crossover blockoff [Re: Pale_Roader] #683537
04/30/10 06:27 AM
04/30/10 06:27 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
1214 for 383 and 1215 for 440
Re: Crossover blockoff [Re: ireland383] #683538
04/30/10 12:55 PM
04/30/10 12:55 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
Thanks everyone, I ordered the 1214 and I'll send the MP back to Summit.
Re: Crossover blockoff [Re: JM67RT] #683539
04/30/10 08:09 PM
04/30/10 08:09 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Yeah, i ordered the MP pan years ago. Assumed it was like the Fel-pro. Boy, was i dissapointed when i opened the box and saw a regular pan with two square pieces of metal provided
Re: Crossover blockoff [Re: forphorty] #683540
04/30/10 08:15 PM
04/30/10 08:15 PM
Kirkland, Washington
Pacnorthcuda Offline
I never understood the two pieces of THICK (about .031 as I recall)metal and how that was supposed to work with out cracking the manifold or leaking terribly.
As others have stated, the Felpro 1215 (for the 440) is the way to go!
Re: Crossover blockoff [Re: Pacnorthcuda] #683541
04/30/10 08:50 PM
04/30/10 08:50 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I've been known to cram a bunch of foil in the crossover.
Re: Crossover blockoff [Re: 375inStroke] #683542
04/30/10 09:19 PM
04/30/10 09:19 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Please forgive my ignorance, but I'm getting ready to do some of the first real engine work I've done in many years. What is the advantage of blocking the crossover? More over, what is the dis-advantage of leaving them open? Thanks, and sorry for the hi-jack
Re: Crossover blockoff [Re: Scott Carl] #683543
04/30/10 09:27 PM
04/30/10 09:27 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
If you use your car in the colder months a lot it warms up faster. If not it can boil the gas at the carb in certain setups.
Re: Crossover blockoff [Re: ireland383] #683544
04/30/10 09:29 PM
04/30/10 09:29 PM
There is also the HP factor. A colder air/fuel charge is denser--makes more power. The colder intake/carb will make more power.
Re: Crossover blockoff [Re: 375inStroke] #683545
04/30/10 09:34 PM
04/30/10 09:34 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I think a BESTer idea is to just FILL the crossover in the intake with some junk aluminum piston that you melted down.
And I read about that HERE ...on moparts !
Re: Crossover blockoff [Re: Pacnorthcuda] #683546
04/30/10 09:36 PM
04/30/10 09:36 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Ah! OK, thanks guys!! Consider mine blocked!
Re: Crossover blockoff [Re: Scott Carl] #683547
05/01/10 01:32 PM
05/01/10 01:32 PM
Under My Car
Mopar_Country Offline
Under My Car
You might notice a slightly longer warm up period from a cold start. The crossover blocked may not be real noticeable on a daily driver, but it can add a tenth at the track.
Re: Crossover blockoff [Re: Mopar_Country] #683548
05/01/10 01:50 PM
05/01/10 01:50 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
If you are running an unmolested stocker you need not worry because the crossover cokes shut thanks to Mopar sloppy valve stem clearances.
As to anything from MP they cranked the prices up to insane levels to make up for sagging car and truck sales.
If the quality was there it might be worth it but ...
