Where did you mount your ignition box? #683353
04/28/10 11:41 PM
04/28/10 11:41 PM
CT
GTX MATT Online content OP
GTX MATT  Online Content OP
CT
Where have you guys mounted your ignition boxes, specifically the Mopar Performance boxes? Pics are welcomed.
Re: Where did you mount your ignition box? [Re: GTX MATT] #683354
04/28/10 11:51 PM
04/28/10 11:51 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Sitting in the seat you cant really see it.. tucked under the dash..
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Where did you mount your ignition box? [Re: CrAlt] #683355
04/28/10 11:53 PM
04/28/10 11:53 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Mounted mine under my drivers seat. It fits nice with no issues moving the seat forward or back.
Re: Where did you mount your ignition box? [Re: SCATPK] #683356
04/29/10 12:37 AM
04/29/10 12:37 AM
Fallon, Nv
SeventyGTX Offline
SeventyGTX  Offline
Fallon, Nv
They say you shouldn't put it under the hood, but I didn't have any problems. Don't worry, the coil was mounted temporarily. I moved it back onto the intake when I got a correct bracket.
Re: Where did you mount your ignition box? [Re: SCATPK] #683357
04/29/10 12:45 AM
04/29/10 12:45 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
glovebox
Re: Where did you mount your ignition box? [Re: ph23vo] #683358
04/29/10 01:37 AM
04/29/10 01:37 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I have a Crane box and it is mounted on the firewall and has been that way for 15 years, FWIW.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Where did you mount your ignition box? [Re: ph23vo] #683359
04/29/10 02:23 AM
04/29/10 02:23 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Top of inner fender:
Ride eternal, shiny and chrome
Re: Where did you mount your ignition box? [Re: DirectSubjection] #683360
04/29/10 07:08 AM
04/29/10 07:08 AM
Leetonia, OH
R6T8net Offline
R6T8net  Offline
Leetonia, OH
Under drivers street for me as well
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
Re: Where did you mount your ignition box? [Re: ph23vo] #683361
04/29/10 11:42 AM
04/29/10 11:42 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
glovebox
Same here
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Where did you mount your ignition box? [Re: GTX MATT] #683362
04/29/10 12:00 PM
04/29/10 12:00 PM
Empire, MI
V
Valiant451 Offline
Valiant451  Offline
V
Empire, MI
Is this the box your looking for? It is in an A-Body, I have never had a problem.
Re: Where did you mount your ignition box? [Re: Valiant451] #683363
04/29/10 12:09 PM
04/29/10 12:09 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
On my dart, I put the digital 6 box on the fenderwell for easy access to the pots (facing back towards firewall)
On my satellite I got a little creative and located the msd6a on the underside of the battery tray. Just barely fits between fenderwell and the brackets but it's nice having it tucked outta the way.
Re: Where did you mount your ignition box? [Re: enelson] #683364
04/29/10 12:16 PM
04/29/10 12:16 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I seen one of the members here out it under the battery tray. Cleans up the engine compartment a little.
For some reason some of the MSD units make a lot of noise, so mounting it into the interior is not a choice.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Where did you mount your ignition box? [Re: GTX MATT] #683365
04/29/10 02:34 PM
04/29/10 02:34 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I have hid them on the radiator support next to the headlights, and under the dash.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Where did you mount your ignition box? [Re: doctor_mopar] #683366
04/29/10 04:07 PM
04/29/10 04:07 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Fire wall
Re: Where did you mount your ignition box? [Re: Boise Chall] #683367
04/29/10 04:51 PM
04/29/10 04:51 PM
Under the battery tray on my '63 Dodge
On the right inner fender like SeventyGTX on my '71 'Cuda.
Re: Where did you mount your ignition box? [Re: ph23vo] #683368
04/29/10 04:56 PM
04/29/10 04:56 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
glovebox
Me too, along with the coil & fuse block
Re: Where did you mount your ignition box? [Re: GTXKen] #683369
04/29/10 05:11 PM
04/29/10 05:11 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Mount my in between the two front seats (MSD-6)on little rubber mounts pretty easy to access the 2-step.
Re: Where did you mount your ignition box? [Re: racerx] #683370
04/29/10 06:18 PM
04/29/10 06:18 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
68 GTX Mopar chrome box mounted to bracket on back of intake. Bracket bolts to the rear valley pan bar. Bracket has slots cut into it for heat. Hides it nicely when hood is open.
Re: Where did you mount your ignition box? [Re: GTX MATT] #683371
04/29/10 08:21 PM
04/29/10 08:21 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
mines on the inner fender behind battery
Re: Where did you mount your ignition box? [Re: terzmo] #683372
04/29/10 09:23 PM
04/29/10 09:23 PM
Dougsmopars Offline
Dougsmopars  Offline
This is the bracket i used. It's for Mopar boxes. Mounts on back of intake. Got it on ebay. Seller is Rocketresto
