Where did you mount your ignition box?
#683353
04/28/10 11:41 PM
04/28/10 11:41 PM
Posts: 5,161 CT
GTX MATT
CT
Where have you guys mounted your ignition boxes, specifically the Mopar Performance boxes? Pics are welcomed.
Re: Where did you mount your ignition box?
[Re: ph23vo]
#683358
04/29/10 01:37 AM
04/29/10 01:37 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have a Crane box and it is mounted on the firewall and has been that way for 15 years, FWIW.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: DirectSubjection]
#683360
04/29/10 07:08 AM
04/29/10 07:08 AM
Posts: 1,546 Leetonia, OH
R6T8net
Leetonia, OH
Under drivers street for me as well
"Who is John Galt?"
68 Coronet RT LL1 Auto 70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far 01 2500 Quad Cab 4x4 Cummins
[Re: enelson]
#683364
04/29/10 12:16 PM
04/29/10 12:16 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I seen one of the members here out it under the battery tray. Cleans up the engine compartment a little.
For some reason some of the MSD units make a lot of noise, so mounting it into the interior is not a choice.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: GTX MATT]
#683365
04/29/10 02:34 PM
04/29/10 02:34 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I have hid them on the radiator support next to the headlights, and under the dash.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: Boise Chall]
#683367
04/29/10 04:51 PM
04/29/10 04:51 PM
Under the battery tray on my '63 Dodge
On the right inner fender like SeventyGTX on my '71 'Cuda.
[Re: terzmo]
#683372
04/29/10 09:23 PM
04/29/10 09:23 PM
Posts: 2,295 dark side of the moon
Dougsmopars
This is the bracket i used. It's for Mopar boxes. Mounts on back of intake. Got it on ebay. Seller is Rocketresto
