340 casting numbers help #682913
04/28/10 08:04 PM
04/28/10 08:04 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Can someone decode these casting numbers from a 69 340
crank PN-2858398
rods - PN-3406782
pistons - PN 2899479
heads - PN 25318940
engine stamping - FW340P29540302
I don't think the crank is original, but any info would be greatly appreciated
thanks,
340kid
Re: 340 casting numbers help [Re: 340KID] #682914
04/28/10 08:10 PM
04/28/10 08:10 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
"heads - PN 25318940" Should be 2531894 = X head.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 340 casting numbers help [Re: 340KID] #682915
04/28/10 08:26 PM
04/28/10 08:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A forged '69 340 crank wouldn't have a casting number, 2858398 is probably 2658393 which is a cast 318 crank.
FW340= Built at the Windsor engine plant
P= Premium fuel
2954= Build date September 29, 1969 (a '70 engine)
0302= Sequence number, the 302nd built that day.
Re: 340 casting numbers help [Re: John_Kunkel] #682916
04/28/10 08:37 PM
04/28/10 08:37 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
is there any major differences in the 318 cast crank versus the original steel crank ?
Re: 340 casting numbers help [Re: 340KID] #682917
04/28/10 08:57 PM
04/28/10 08:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
F is the series (model year) 1970.
What are the 8 digits on the pad on the passenger side of the block right above the oil pan?
Re: 340 casting numbers help [Re: Alaskan_TA] #682918
04/28/10 09:37 PM
04/28/10 09:37 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
2780930-340
Re: 340 casting numbers help [Re: Alaskan_TA] #682919
04/28/10 09:59 PM
04/28/10 09:59 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
sorry I posted wrong number in prior post
OB172376
Re: 340 casting numbers help [Re: 340KID] #682920
04/28/10 10:00 PM
04/28/10 10:00 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Looks like you got it.
other side... here. It's on the side with the oil filter on a SB.
Re: 340 casting numbers help [Re: RobX4406] #682921
04/28/10 10:04 PM
04/28/10 10:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Thanks! New number to me, it is from a Duster.
Re: 340 casting numbers help [Re: Alaskan_TA] #682922
04/28/10 10:10 PM
04/28/10 10:10 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
great, i'm getting this motor for my son's 72 Duster project, should be a nice fit, it will be replacing a 72 318
340kid
Re: 340 casting numbers help [Re: 340KID] #682923
04/28/10 10:39 PM
04/28/10 10:39 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
crank PN-2858398
rods - PN-3406782
heads - PN 25318940
does anyone have info if the pistons and rods are originals ?
thanks,
340kid
Re: 340 casting numbers help [Re: 340KID] #682924
10/07/10 05:00 PM
10/07/10 05:00 PM
Can anyone help me ID this block...?
Casting Number 2780930-340-3
Date 7-11-69
VIN pad 0B210544
Thank you
Re: 340 casting numbers help #682925
10/07/10 05:14 PM
10/07/10 05:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The partial VIN indicates that it came from a 1970 Hamtramck car. I do not have anything close enough to it to know exactly which model.
Possibles are Duster, Cuda or Challenger for this plant with the 340.
Re: 340 casting numbers help [Re: Alaskan_TA] #682926
10/07/10 10:39 PM
10/07/10 10:39 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
not sure on the differences with the steel crank,other than balance. but, in 72-73 340's they used a cast crank,which is the same crank and rods as the 318 uses. only the 318 will have a neutral balancer,and the cast crank uses it's own specific "340 cast crank" balancer.i have done alot of digging and found that if you are looking for a remanufactured crank and rods for a 70's 318,they are the same identical parts for a 72-73 340. as i had to do,just have to have the right balancer. (heavier pistons make it necessary)
Re: 340 casting numbers help [Re: 340KID] #682927
10/19/10 05:01 PM
10/19/10 05:01 PM
Date 7-11-69
VIN pad 0B210544 oil pan rail
VIN FW340P30420600 front of block
Second Block
VIN FW340P30100484 front of block
Thank you
Re: 340 casting numbers help #682928
10/19/10 07:00 PM
10/19/10 07:00 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
it's a 1970 340. pretty simple.
Re: 340 casting numbers help [Re: superbyrd] #682929
10/20/10 12:19 PM
10/20/10 12:19 PM
wanting to know what it came out of if possible...?
Re: 340 casting numbers help #682930
10/20/10 06:30 PM
10/20/10 06:30 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
a 70 model dart 'cuda,challenger,duster. kind of hard to tell a specific car it came from.
Re: 340 casting numbers help [Re: superbyrd] #682931
10/20/10 06:34 PM
10/20/10 06:34 PM
RobX4406 Offline
RobX4406  Offline
Can't be a Dart. Not built at that plant.
Re: 340 casting numbers help [Re: RobX4406] #682932
10/20/10 08:17 PM
10/20/10 08:17 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
ok. that rules out the dart. it's not a T/A block,so,not sure what it would matter what it came from,unless you are wanting that specific info to use for some woooo factor in trying to sell it to some loser that doesn't know any better and thinks it's "special" because it came out of a 'cuda.a 70 340,is just a 70 340. unless you have the vin# or sequential number from that given car,gonna be kind of tough.
