Re: 340 casting numbers help
[Re: 340KID]
#682914
04/28/10 08:10 PM
04/28/10 08:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
"heads - PN 25318940" Should be 2531894 = X head.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: 340KID]
#682915
04/28/10 08:26 PM
04/28/10 08:26 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A forged '69 340 crank wouldn't have a casting number, 2858398 is probably 2658393 which is a cast 318 crank.
engine stamping - FW340P29540302
FW340= Built at the Windsor engine plant P= Premium fuel 2954= Build date September 29, 1969 (a '70 engine) 0302= Sequence number, the 302nd built that day.
[Re: Alaskan_TA]
#682918
04/28/10 09:37 PM
04/28/10 09:37 PM
Posts: 549 CT
340KID
CT
[Re: 340KID]
#682923
04/28/10 10:39 PM
04/28/10 10:39 PM
Posts: 549 CT
340KID
CT
Can someone decode these casting numbers from a 69 340 crank PN-2858398 rods - PN-3406782 pistons - PN 2899479 heads - PN 25318940 engine stamping - FW340P29540302
I don't think the crank is original, but any info would be greatly appreciated
does anyone have info if the pistons and rods are originals ?
thanks, 340kid
[Re: 340KID]
#682924
10/07/10 05:00 PM
10/07/10 05:00 PM
Can anyone help me ID this block...?
Casting Number 2780930-340-3 Date 7-11-69 VIN pad 0B210544
Thank you
[Re: 340KID]
#682927
10/19/10 05:01 PM
10/19/10 05:01 PM
Casting Number 2780930-340-3 Date 7-11-69 VIN pad 0B210544 oil pan rail VIN FW340P30420600 front of block
Second Block
VIN FW340P30100484 front of block
Thank you
[Re: superbyrd]
#682929
10/20/10 12:19 PM
10/20/10 12:19 PM
wanting to know what it came out of if possible...?
