Re: What gears do I have?
[Re: Scott Carl]
#682427
04/27/10 11:40 PM
04/27/10 11:40 PM
Posts: 356 NE
moparpoolman
NE
For a non sure grip multiply the rotation of drive shaft by 2 Make sure one tire is not spinning, chocked or on the ground
[Re: Scott Carl]
#682428
04/27/10 11:48 PM
04/27/10 11:48 PM
RapidRobert
Jack 1 tire just off the ground, in neutral, put valve stem @12 O'clock, turn wheel back to 12 O'clock twice (2 revolutions) and count the driveshaft revolutions. 3&1/2 is 3:55, 3:23 is 3&1/4, 3:91 is slightly less than 4 turns and 4:10 is slightly over 4 turns and 4&1/2 turns is 4:56
