What gears do I have? #682426
04/27/10 11:37 PM
04/27/10 11:37 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
Is there a way to determine the gear ratio of a rear-end without pulling the carrier? I have a stock 8 3/4 in my '74 Challenger. I understand ther could be several different gears but I'm just looking for a ballpark figure. Need to see if I'm going to have to re-gear for the cam I want to use. I thought you could turn the yoke and count how many times it takes to turn the tire once, but does that work for a non-suregrip?
Re: What gears do I have? [Re: Scott Carl] #682427
04/27/10 11:40 PM
04/27/10 11:40 PM
NE
moparpoolman Offline
NE
For a non sure grip multiply the rotation of drive shaft by 2 Make sure one tire is not spinning, chocked or on the ground
Re: What gears do I have? [Re: Scott Carl] #682428
04/27/10 11:48 PM
04/27/10 11:48 PM
Jack 1 tire just off the ground, in neutral, put valve stem @12 O'clock, turn wheel back to 12 O'clock twice (2 revolutions) and count the driveshaft revolutions. 3&1/2 is 3:55, 3:23 is 3&1/4, 3:91 is slightly less than 4 turns and 4:10 is slightly over 4 turns and 4&1/2 turns is 4:56
Re: What gears do I have? [Re: RapidRobert] #682429
04/28/10 12:20 AM
04/28/10 12:20 AM
Omaha, Nebraska
Omaha, Nebraska
Thanks guys! Seems pretty straight forward.
Hey Robert, did you get my last PM?
Re: What gears do I have? [Re: Scott Carl] #682430
04/28/10 12:29 AM
04/28/10 12:29 AM
yeah I did but w PM's it always takes me time to formulate an intelligent response (ain't that right Scratch )
Re: What gears do I have? [Re: RapidRobert] #682431
04/28/10 12:33 AM
04/28/10 12:33 AM
Omaha, Nebraska
Omaha, Nebraska
LOL No problem and no hurry
