sending unit #682046
04/27/10 08:11 PM
04/27/10 08:11 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
finishing my restoration and I put a new gas tank in and sending unit in. I put 12 gal of gas and the gauge only register 1/8th of a tank. any ideas I surely don't want to put in another sending unit. Thanks
Re: sending ubit [Re: 70 buzz] #682047
04/27/10 08:17 PM
04/27/10 08:17 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
12 is half a tank?
Take out the sending unit and bend the float wire down.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: sending ubit [Re: amxautox] #682048
04/27/10 09:09 PM
04/27/10 09:09 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
I think it holds 19 gallon
Re: sending unit [Re: 70 buzz] #682049
04/28/10 12:17 AM
04/28/10 12:17 AM
jump the metal flat face of the sending unit to the fuel line to confirm that it is not a ground issue before opening it up but w all the sending unit difficulties I'd say as said it needs to come out and check it's ohms w the arm all the way down/up & iirc you want 73 "down" and 10 "up" plus you can plug in the hot wire and ground it w a jumper wire w alligator clips on each end and move it up and down and have a helper watch the gauge up front (key on) and see what he sees. You want very close to those ohm amts before you bend the arm.
