360 balance plate by KMJ?? #681857
04/27/10 03:21 PM
04/27/10 03:21 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Im swapping the 318 for a 360 in my sweptline. I need to find a way to balance the flywheel, I have a NP 4speed. Ive thought about drilling the 3 holes in my flywheel as I havent found a used 360 truck 4 speed wheel yet. I then happened upon this item. It sounds too good to be true. Its a 6 hole crank balance plate the fits between the crank and flywheel. Has anyone used this or heard of this? Any feed backs? Thanks for the help.
http://www.kmjent.com/cart/product.php?productid=2077
68 fish
Re: 360 balance plate by KMJ?? [Re: RonaldV] #681858
04/27/10 03:29 PM
04/27/10 03:29 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
My only question would be about how it affects the starter/flywheel relationship.
Re: 360 balance plate by KMJ?? [Re: John_Kunkel] #681859
04/27/10 03:31 PM
04/27/10 03:31 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
I called them today. They said that they cant keep this item in stock. In the past 6 months they have sold over 30 of them. No complaints. I asked about the starter gear meshing with the flywheel. They said it works with no problems. Id like to hear this from someone who used the product.
Ron
Re: 360 balance plate by KMJ?? [Re: RonaldV] #681860
04/27/10 07:24 PM
04/27/10 07:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've done the same "trick" using a B&M flexplate for the 360, sandwich it between the flywheel and crank. Never had an issue with tooth engagement.
Don't be the exception.
Re: 360 balance plate by KMJ?? [Re: Supercuda] #681861
04/27/10 09:26 PM
04/27/10 09:26 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Did you get any vibration?
Re: 360 balance plate by KMJ?? [Re: RonaldV] #681862
04/27/10 10:18 PM
04/27/10 10:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, none at all.
Re: 360 balance plate by KMJ?? [Re: Supercuda] #681863
03/30/12 08:11 PM
03/30/12 08:11 PM
SE PA
Yellow Fever Offline
SE PA
Going the 318 to 360 route, has anyone used this yet? Great price if it works!
Re: 360 balance plate by KMJ?? [Re: Yellow Fever] #681864
03/30/12 09:08 PM
03/30/12 09:08 PM
I have used it in a bunch of applications--It works with flywheels NO issues yet--I have even used it with 400 and 440 cast cranks and guess what? They run smooth enough you would never know--a wonder product if ever there was one--and they are a MUST if you have a stock internal balance flywheel on your test stand--you can run anything
Re: 360 balance plate by KMJ?? [Re: ] #681865
04/02/12 02:33 PM
04/02/12 02:33 PM
dogdays Offline
dogdays  Offline
And chevy racers have been doing the same thing for years.
R.
Re: 360 balance plate by KMJ?? [Re: dogdays] #681866
04/02/12 03:20 PM
04/02/12 03:20 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I sent the guy at Quik time the technical data to build those for a dodge 360 he already had one for the 440. Anyhow glad to see he actually made them. He never got back to me on them so I didn't know if he made them or not.
Re: 360 balance plate by KMJ?? [Re: mod5v] #681867
12/04/14 05:06 PM
12/04/14 05:06 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I'm wondering if more people have tried this here yet. I tried going to the site that was posted up above...but I couldn't even email them....but I did find the part on Summit and QuickTime sites. Lakewood Summit
Moparlee
Re: 360 balance plate by KMJ?? [Re: Robbins] #681868
12/04/14 05:17 PM
12/04/14 05:17 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I'd have to admit that is a little scary....if you look at McLeod SFI flywheels that sell a screw on plates for externally balanced stuff for mopar and they are not the same plates for the 360,400/440
Moparlee
Re: 360 balance plate by KMJ?? [Re: Robbins] #681869
12/04/14 05:52 PM
12/04/14 05:52 PM
dogdays Offline
dogdays  Offline
Well, it's a little discouraging that they don't specify what it's for, I'm assuming 360s. On the other hand, chevy guys have been doing this for decades, running neutral balanced flywheels on 400s and 454s. Some have even sandwiched a flexplate with the right imbalance between either the flexplate or the flywheel.
One could put this plate behind a flywheel or behind a flexplate. Doesn't matter, if the bolts are loaded properly.
R.
Re: 360 balance plate by KMJ?? [Re: dogdays] #681870
12/04/14 08:03 PM
12/04/14 08:03 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have one of those, but I am going to use an automatic when I build the 360 that I have for my truck and would be willing to sell the one I have for cheap, shipped. Send me a PM if interested.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
