OIL WITH ZINC #68154
06/05/08 05:48 PM
06/05/08 05:48 PM
Anonymous OP
Anonymous OP
DOES ANYONE KNOW WHAT MOTOR OIL HAS ZINC IN IT. I BELIEVE VALOLINE MIGHT BUT DON'T KNOW FOR SURE
THANKS MOPARTS
Re: OIL WITH ZINC #68155
06/05/08 05:50 PM
06/05/08 05:50 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
THANKS MOPARTS
Do a search on the ZDDP posts here and you will find lots of info. ALso, yes the valvoline RACE oils 10-30 and 20-50 have it.
Re: OIL WITH ZINC [Re: Dart 340] #68156
06/05/08 05:58 PM
06/05/08 05:58 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Re: OIL WITH ZINC #68157
06/05/08 05:59 PM
06/05/08 05:59 PM
Kirkland, Washington
Pacnorthcuda Offline
The diesel oils are a good choice.
Shell Rotella 15w40
Chevron Delo 15w40
The above are available in CJ-4 formulation.
Even better is CI-4 formulations such as Chevron Delo 10w-30.
Its alll a bit of a krap-shoot because the zinc level can be decreased at any time without any requirement that the CJ-4 be rolled over to "CK"
But diesel engines have a greater need for a 'decent level' of zinc than modern roller cammed auto engines so they are a viable choice. You could certainly do worse!
A zinc additive like ZDDPlus would be great, even STP RED helps.
Re: OIL WITH ZINC #68158
06/05/08 06:00 PM
06/05/08 06:00 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
THANKS MOPARTS
You have to look at the API service rating. If the oil has an SM or CJ-4 rating the zinc content has been reduced to approx 800 ppm. If doesn't matter the brand the API rating mandates the level of zinc allowed and it's monitored by the government.
The older API ratings SJ, SL or CI-4 are the oils you want to look for.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: OIL WITH ZINC [Re: dgc333] #68159
06/05/08 06:09 PM
06/05/08 06:09 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
look in the yellow pages and find out who is the local SHELL distributor. Ask them if they have/can get Rotella CI-4
in the 5 gallon pales. Probably can get you all you want. I picked up 5 !
Re: OIL WITH ZINC [Re: VanishPt] #68160
06/05/08 07:52 PM
06/05/08 07:52 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I can get Rotella CI-4 at my local Autozone.....
Re: OIL WITH ZINC #68161
06/06/08 12:44 PM
06/06/08 12:44 PM
Locomotion Offline
Locomotion  Offline
Amsoil has a few that retain a very high zinc content. Their descriptions usually mention "older vehicles" or "pre-2007".
Their Series 3000 5w-30 HDD diesel oil has something like 1200-1300ppm of zinc, last time I checked. I'm out of town and can't double-check my records at home.
Amsoil source & info page.
Most oils, even diesle, have gone down. It's difficult to keep up with the changes and finding exactly what the "current" ones have.
Re: OIL WITH ZINC #68162
06/06/08 01:09 PM
06/06/08 01:09 PM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
I used this .
Re: OIL WITH ZINC [Re: JS29] #68163
06/06/08 02:09 PM
06/06/08 02:09 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Other oils with a decent amount of zinc are the 5W40 synthetic oils such as Shell Rotella, Valvoline Extreme Blue, Chevron Delo 400, or a heavier synthetic such as 15W50 Mobil 1 EP.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: OIL WITH ZINC [Re: Locomotion] #68164
06/06/08 02:34 PM
06/06/08 02:34 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I agree with Locomotion on the AMSOIL.
Click on the the provided link above, it's a Technical Service Bulletin from AMSOIL about Zinc and Phosphorous content and and Flat Tappet Camshafts.
Also, AMSOIL is the Official Motor Oil of the 2007 & 2008 AMSOIL/MOPAR MUSCLE ENGINE CHALLENGE as seen in Mopar Muscle Magazine. In the this engine challenge, engine entries are filled to capacity with AMSOIL #AMO 10W-40 Motor Oil. A lot of the entries utilize flat tappet camshafts to keep costs down. All the engines have to be able to reach a maximum RPM of 7000 RPMs, and do it six times during the challenge. After the challenge, the engines are torn down to make sure that the contestants used approved parts in their builds. Other notes are made such as how the engine bearings look. In all, they look brand new. In my opinion, the is a great testimony to not only awesome engine building, but also how well AMSOIL Motor Oil stands up in extreme conditions in high horsepower engines.
Re: OIL WITH ZINC [Re: dgc333] #68165
06/06/08 02:38 PM
06/06/08 02:38 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Actually there are several CJ-4 oils with more than that. The last time I looked into it (and changed my oil, couple months ago) I used Delo 400 which has about 1300 PPM. Rotella has about 1200 PPM. Both are the new formulation CJ-4 and are available anywhere including Walmart in a 1 gallon jug.
I also used 1 quart "stp oil stabilizer" which when mixed with 4 quarts of Delo, brought the zinc PPM up about 80 PPM for the whole 5 quarts, if I remember right.
Re: OIL WITH ZINC [Re: Exit1965] #68166
06/06/08 04:55 PM
06/06/08 04:55 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I just switched to Joe Gibb Hotrod oil. The diesels oils are giving me too much oil pressure (40 psi hot idle, almost 80psi at 2000rpm hot). If the cam falls out, I'll let you know
