OIL WITH ZINC
#68154
06/05/08 05:48 PM
06/05/08 05:48 PM
DOES ANYONE KNOW WHAT MOTOR OIL HAS ZINC IN IT. I BELIEVE VALOLINE MIGHT BUT DON'T KNOW FOR SURE
THANKS MOPARTS
Re: OIL WITH ZINC
#68155
06/05/08 05:50 PM
06/05/08 05:50 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
THANKS MOPARTS
Do a search on the ZDDP posts here and you will find lots of info. ALso, yes the valvoline RACE oils 10-30 and 20-50 have it.
Re: OIL WITH ZINC
#68158
06/05/08 06:00 PM
06/05/08 06:00 PM
Posts: 1,396 Mass
dgc333
Mass
THANKS MOPARTS
You have to look at the API service rating. If the oil has an SM or CJ-4 rating the zinc content has been reduced to approx 800 ppm. If doesn't matter the brand the API rating mandates the level of zinc allowed and it's monitored by the government.
The older API ratings SJ, SL or CI-4 are the oils you want to look for.
Re: OIL WITH ZINC
#68161
06/06/08 12:44 PM
06/06/08 12:44 PM
Posts: 5,894 Florida
Locomotion
Amsoil has a few that retain a very high zinc content. Their descriptions usually mention "older vehicles" or "pre-2007". Their Series 3000 5w-30 HDD diesel oil has something like 1200-1300ppm of zinc, last time I checked. I'm out of town and can't double-check my records at home. Amsoil source & info page.Most oils, even diesle, have gone down. It's difficult to keep up with the changes and finding exactly what the "current" ones have.
Re: OIL WITH ZINC
[Re: Locomotion]
#68164
06/06/08 02:34 PM
06/06/08 02:34 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I agree with Locomotion on the AMSOIL. Click on the the provided link above, it's a Technical Service Bulletin from AMSOIL about Zinc and Phosphorous content and and Flat Tappet Camshafts. Also, AMSOIL is the Official Motor Oil of the 2007 & 2008 AMSOIL/MOPAR MUSCLE ENGINE CHALLENGE as seen in Mopar Muscle Magazine. In the this engine challenge, engine entries are filled to capacity with AMSOIL #AMO 10W-40 Motor Oil. A lot of the entries utilize flat tappet camshafts to keep costs down. All the engines have to be able to reach a maximum RPM of 7000 RPMs, and do it six times during the challenge. After the challenge, the engines are torn down to make sure that the contestants used approved parts in their builds. Other notes are made such as how the engine bearings look. In all, they look brand new. In my opinion, the is a great testimony to not only awesome engine building, but also how well AMSOIL Motor Oil stands up in extreme conditions in high horsepower engines.
Re: OIL WITH ZINC
[Re: dgc333]
#68165
06/06/08 02:38 PM
06/06/08 02:38 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Actually there are several CJ-4 oils with more than that. The last time I looked into it (and changed my oil, couple months ago) I used Delo 400 which has about 1300 PPM. Rotella has about 1200 PPM. Both are the new formulation CJ-4 and are available anywhere including Walmart in a 1 gallon jug.
I also used 1 quart "stp oil stabilizer" which when mixed with 4 quarts of Delo, brought the zinc PPM up about 80 PPM for the whole 5 quarts, if I remember right.
Re: OIL WITH ZINC
[Re: Exit1965]
#68166
06/06/08 04:55 PM
06/06/08 04:55 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I just switched to Joe Gibb Hotrod oil. The diesels oils are giving me too much oil pressure (40 psi hot idle, almost 80psi at 2000rpm hot). If the cam falls out, I'll let you know
