Can you swap PP833 overdrive into a standard case #681366
04/26/10 11:03 PM
04/26/10 11:03 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I have an aluminum case overdrive transmission that I would like to convert into a cast standard case.
Can this be done?
Will cluster shaft fit
Can the 308 input bearing be changed to a 307?
Any input would be greatly appreciated
Re: Can you swap PP833 overdrive into a standard case [Re: Dart6pak] #681367
04/26/10 11:51 PM
04/26/10 11:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes. All gears and mainshaft MUST be swapped together. Use the cluster pin from the cast iron case. Also use the 307 bearing and corresponding front bearing retainer. Some tailhousings used a different bearing. If this is the case, use the bearing from the iron tailhousing.
The only caveat here is that you can't swap a long tail OD mainshaft into a short tailhousing A/F body
Re: Can you swap PP833 overdrive into a standard case [Re: Jim_Lusk] #681368
04/27/10 10:09 AM
04/27/10 10:09 AM
michigan woods
imfixinmopars426 Offline
michigan woods
od truck is same as a b/e length
Re: Can you swap PP833 overdrive into a standard case [Re: Dart6pak] #681369
04/27/10 10:37 AM
04/27/10 10:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The cluster shaft will work but it's a little short and you'll want to seal it somehow or it will leak ... been there got the spot on the floor to show for it .
Re: Can you swap PP833 overdrive into a standard case [Re: JohnRR] #681370
04/27/10 11:04 AM
04/27/10 11:04 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Hence the reason I said to use the iron case pin....
