Transmission Cradle #680754
04/26/10 02:34 PM
04/26/10 02:34 PM
Indy
moparman89 Offline OP
Indy
Does anyone know where I can get a transmission cradle for a 727? I've had no luck in finding someone who sells them.
School of Automotive Machinists Racing
Re: Transmission Cradle [Re: moparman89] #680755
04/26/10 02:49 PM
04/26/10 02:49 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Made one from a piece of plywood, angle iron bolted to one end with holes drilled for the top bellhousing bolts and a vertical 2x4 with a diagional brace just before the tailshaft to hold the trans upside down on a workbench. Works like a charm.
Re: Transmission Cradle [Re: moparman89] #680756
04/26/10 02:55 PM
04/26/10 02:55 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
ALL I did was use a 13 or 14 inch steel wheel(put the bell-housing in that) ...and use a simple jack-stand on the tail housing.
I used this combo on a couple-of-hundred transmissions....
