tough paint question #680652
04/26/10 01:26 PM
04/26/10 01:26 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
I am getting ready to paint a 70 Roadrunner. In California, we must use water base paint. My car will have the hood stripe treatment and I want to use the Organisol. What prepartation do I have to do OR will the organisol adhere to the waterbase without any problems. ALSO, the waterbase requires a clear coat. Do I clear over the Organisol or what should I do?
Re: tough paint question [Re: TrueTripleX] #680653
04/26/10 01:31 PM
04/26/10 01:31 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Get the car painted in another state.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: tough paint question [Re: MOPARMIKE69] #680654
04/26/10 01:45 PM
04/26/10 01:45 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
next year water based base coat will be required nation wide.
Re: tough paint question [Re: MOPARMIKE69] #680655
04/26/10 02:03 PM
04/26/10 02:03 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
71 scamp big block with 915 heads 727 trans
Re: tough paint question [Re: 05dakota] #680656
04/26/10 03:03 PM
04/26/10 03:03 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
And hurry
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: tough paint question [Re: TrueTripleX] #680657
04/26/10 05:09 PM
04/26/10 05:09 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Paint the car base / clear. After buff and polish tape off scuff and paint your stripes. Yes it will stick just fine to water bourne paint system. Get used to it guys water base will be nation wide with in a couple of years. Don't knock water bourne till you try it. I'm in RI and we're getting ready to change over this year. Water bourne is a nice system.
Re: tough paint question [Re: Dougsmopars] #680658
04/26/10 07:23 PM
04/26/10 07:23 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
Haven't heard a word about mandatory waterborne here in Michigan but the EPA is on our backs about airborne solvents.I'm sure it will be soon for us as well and it is a nice system.I would base/clear/rub and paint on the stripe.I've sprayed just about everything one time or another and the only problem I can see with waterborne is color match,maybe.
Re: tough paint question [Re: MOPARMIKE69] #680659
04/26/10 08:48 PM
04/26/10 08:48 PM
Jacksonville Florida
elitecustombody Offline
Re: tough paint question [Re: 05dakota] #680660
04/26/10 09:59 PM
04/26/10 09:59 PM
BFE
vancamp Offline
super street
vancamp  Offline
super street
BFE
according to ppg it will be at least another 4-5 years here before it is mandattory if then according to them they are hitting the large metro areas first, waterborne can be a good system if done correctly, like anything else. and to answer the original question spray your color and clear and put the organisol over the top of the clear.
VanCamp Dent Systems Paintless Dent Repair/ Mopar Restification
