Will Stock Valve Springs handle a cam? #680572
04/26/10 10:53 AM
04/26/10 10:53 AM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Im thinking of putting a cam in the 360 in my truck, it has 308 heads with stock springs and retainers. I dont have much cash so was thinking on cam and lifters as opposed to springs and retainers too. The cam is a Comp 268 Grind heres the specs
Basic Operating RPM Range 1,600-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 224 int./230 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 280
Advertised Duration 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.480 in.
Valve Lift with Factory Rocker Arm Ratio 0.477 int./0.480 exh. lift
Lobe Separation (degrees) 110
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Grind Number CRS XE268H-10
Re: Will Stock Valve Springs handle a cam? [Re: EV2RUNNER] #680573
04/26/10 11:14 AM
04/26/10 11:14 AM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I always replace the springs, with a new cam it is cheap insurance. But if you want to use your old ones, the biggest thing to check for is coil bind. If you were using a cam with .5 inch lift I'd say no, but you might get away with it with the cam you picked. I think I paid around $50 for a set of Engle springs for my 340, and so far so good. It runs excellent, and revs just fine.
Re: Will Stock Valve Springs handle a cam? [Re: EV2RUNNER] #680574
04/26/10 11:15 AM
04/26/10 11:15 AM
Under My Car
Mopar_Country Offline
Under My Car
That camshaft will require some head work, as well as different springs and adjustable valve train. I just put this cam in my 318
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=619&sb=2
it works very well and I think it will work for you as well. You can buy the kit for just over 300.00 which will include the cam, lifters, springs and retainers, and locks. The kit also has a new timing chain and gears. I would recommend that kit instead of just replacing the cam. Your stock valvetrain will work. Be sure of which way you take the rockers and bar off as they are specific, for oiling purposes.
Re: Will Stock Valve Springs handle a cam? [Re: Mopar_Country] #680575
04/26/10 11:28 AM
04/26/10 11:28 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use the springs that are rated for the cam. Also a lot of 360's have rotators on the exhaust valves further limiting the amount of cam that can be safely used because they shorten the installed height and travel of the valve. Get rid of the rotators and use a regular retainer just like the ones on the intake valves.
Re: Will Stock Valve Springs handle a cam? [Re: MoparforLife] #680576
04/26/10 11:40 AM
04/26/10 11:40 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
use comp #901 springs and stock non-rotator retainers...should add another $60 to the price....
while it's apart, it's smart insurance to replace the t-chain, too...
2017 Grand Cherokee Overland
Re: Will Stock Valve Springs handle a cam? [Re: Mopar_Country] #680577
04/26/10 11:45 AM
04/26/10 11:45 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no it doesn't...all it needs are stock rockers, locks, retainers and comp #901 springs.
if it's a stock long block 360 with low comp, and in a heavy vehicle, like a truck typically is, I wouldn't go bigger than an XE262. if it has a low stall converter, don't go bigger than an XE256.
Re: Will Stock Valve Springs handle a cam? [Re: patrick] #680578
04/26/10 11:58 AM
04/26/10 11:58 AM
Upper Midwest
Upper Midwest
I agree with you Patrick. Have seen a lot bigger more aggressive cams with out any additional head work other than some decent springs.If much over 500 lift a trim on the guides but that is nothing scientific and cam be done at home as long as you use regular umbrella valve seals
Re: Will Stock Valve Springs handle a cam? [Re: EV2RUNNER] #680579
04/26/10 12:21 PM
04/26/10 12:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Will Stock Valve Springs handle a cam? [Re: Dodgem] #680580
04/26/10 02:21 PM
04/26/10 02:21 PM
Upper Midwest
Upper Midwest
BTW pictured is the partial results of using a .474 lift cam with stock springs and rotators. also took blew out a head, cam, hole in block, and couple bent rods.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Will Stock Valve Springs handle a cam? [Re: MoparforLife] #680581
04/26/10 10:26 PM
04/26/10 10:26 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I ran a MP509 with stock 587s for a LONG time with no problems whatsoever
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Will Stock Valve Springs handle a cam? [Re: 69L78Nova] #680582
04/26/10 10:49 PM
04/26/10 10:49 PM
Upper Midwest
Upper Midwest
Some people get lucky. You also must have found one without rotators. No way that it would have gone with rotator retainers.
Re: Will Stock Valve Springs handle a cam? [Re: MoparforLife] #680583
04/26/10 11:15 PM
04/26/10 11:15 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
No, it did not have rotators
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Will Stock Valve Springs handle a cam? [Re: 69L78Nova] #680584
04/27/10 07:04 AM
04/27/10 07:04 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
No, you need springs to match the cam as mentionned...
Re: Will Stock Valve Springs handle a cam? [Re: EV2RUNNER] #680585
04/27/10 07:37 AM
04/27/10 07:37 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Get the springs. Do it right or don't do it at all. You know this hobby ain't cheap.
Re: Will Stock Valve Springs handle a cam? [Re: dustergirl340] #680586
04/27/10 11:13 AM
04/27/10 11:13 AM
Under My Car
Under My Car
I misspoke when I said it required head work. What I meant to say, to clarify, that some work will need to be done to the heads as in springs, locks etc. Comp cams DOES recommend running an adjustable valve train with the XE268H
[7] Stock springs cannot be used.
[23] Includes special shafts & spacers.
[37] Adjustable valve train required.
I would suggest calling comp cams tech line for your peace of mind. You certainly don't want what you see in the pic's posted here in your day.
Re: Will Stock Valve Springs handle a cam? [Re: EV2RUNNER] #680587
04/27/10 11:25 AM
04/27/10 11:25 AM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
As mentioned several times, get the rated springs for the cam. Even if you dont bind the springs, you'll be asking why there's no performance gain because the valves are bouncing off the seats at 5000 rpm. Just my $.02
Dakota for life!
Re: Will Stock Valve Springs handle a cam? [Re: Scojodak] #680588
04/27/10 01:29 PM
04/27/10 01:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Funny you mention 5000 rpm because I put an XE268 in a 360 with stock springs when I was younger and 5000 was like a rev limiter kicked in, I even tried shimming the springs to virtual coil bind and it would not do noticably better, when I put in good springs it was fine to 6000, and just smoothly lost power instead of all the popping and crap with the stock springs. It had ported 302 heads on it and made great TQ.
Re: Will Stock Valve Springs handle a cam? [Re: MoparforLife] #680589
04/28/10 10:48 AM
04/28/10 10:48 AM
St.Clairsville Ohio
St.Clairsville Ohio
Valve Springs suddenly look very CHEAP After viewing this pic...My Mind's made up Thanks all!
