Will Stock Valve Springs handle a cam?
#680572
04/26/10 10:53 AM
04/26/10 10:53 AM
Posts: 433 St.Clairsville Ohio
EV2RUNNER
St.Clairsville Ohio
Im thinking of putting a cam in the 360 in my truck, it has 308 heads with stock springs and retainers. I dont have much cash so was thinking on cam and lifters as opposed to springs and retainers too. The cam is a Comp 268 Grind heres the specs Basic Operating RPM Range 1,600-5,800 Intake Duration at 050 inch Lift 224 Exhaust Duration at 050 inch Lift 230 Duration at 050 inch Lift 224 int./230 exh. Advertised Intake Duration 268 Advertised Exhaust Duration 280 Advertised Duration 268 int./280 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.477 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.480 in. Valve Lift with Factory Rocker Arm Ratio 0.477 int./0.480 exh. lift Lobe Separation (degrees) 110 Intake Valve Lash 0.000 in. Exhaust Valve Lash 0.000 in. Grind Number CRS XE268H-10 Thanks
Re: Will Stock Valve Springs handle a cam?
[Re: EV2RUNNER]
#680574
04/26/10 11:15 AM
04/26/10 11:15 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
That camshaft will require some head work, as well as different springs and adjustable valve train. I just put this cam in my 318 http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=619&sb=2 it works very well and I think it will work for you as well. You can buy the kit for just over 300.00 which will include the cam, lifters, springs and retainers, and locks. The kit also has a new timing chain and gears. I would recommend that kit instead of just replacing the cam. Your stock valvetrain will work. Be sure of which way you take the rockers and bar off as they are specific, for oiling purposes.
[Re: MoparforLife]
#680576
04/26/10 11:40 AM
04/26/10 11:40 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
use comp #901 springs and stock non-rotator retainers...should add another $60 to the price....
while it's apart, it's smart insurance to replace the t-chain, too...
[Re: Mopar_Country]
#680577
04/26/10 11:45 AM
04/26/10 11:45 AM
patrick
Grand Haven, MI
no it doesn't...all it needs are stock rockers, locks, retainers and comp #901 springs.
if it's a stock long block 360 with low comp, and in a heavy vehicle, like a truck typically is, I wouldn't go bigger than an XE262. if it has a low stall converter, don't go bigger than an XE256.
[Re: patrick]
#680578
04/26/10 11:58 AM
04/26/10 11:58 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I agree with you Patrick. Have seen a lot bigger more aggressive cams with out any additional head work other than some decent springs.If much over 500 lift a trim on the guides but that is nothing scientific and cam be done at home as long as you use regular umbrella valve seals
[Re: MoparforLife]
#680581
04/26/10 10:26 PM
04/26/10 10:26 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I ran a MP509 with stock 587s for a LONG time with no problems whatsoever
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#680582
04/26/10 10:49 PM
04/26/10 10:49 PM
MoparforLife
Upper Midwest
Some people get lucky. You also must have found one without rotators. No way that it would have gone with rotator retainers.
[Re: MoparforLife]
#680583
04/26/10 11:15 PM
04/26/10 11:15 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
No, it did not have rotators
[Re: 69L78Nova]
#680584
04/27/10 07:04 AM
04/27/10 07:04 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
No, you need springs to match the cam as mentionned...
[Re: EV2RUNNER]
#680587
04/27/10 11:25 AM
04/27/10 11:25 AM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
As mentioned several times, get the rated springs for the cam. Even if you dont bind the springs, you'll be asking why there's no performance gain because the valves are bouncing off the seats at 5000 rpm. Just my $.02
Dakota for life!
[Re: Scojodak]
#680588
04/27/10 01:29 PM
04/27/10 01:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Funny you mention 5000 rpm because I put an XE268 in a 360 with stock springs when I was younger and 5000 was like a rev limiter kicked in, I even tried shimming the springs to virtual coil bind and it would not do noticably better, when I put in good springs it was fine to 6000, and just smoothly lost power instead of all the popping and crap with the stock springs. It had ported 302 heads on it and made great TQ.
[Re: MoparforLife]
#680589
04/28/10 10:48 AM
04/28/10 10:48 AM
EV2RUNNER
St.Clairsville Ohio
BTW pictured is the partial results of using a .474 lift cam with stock springs and rotators. also took blew out a head, cam, hole in block, and couple bent rods.
Valve Springs suddenly look very CHEAP After viewing this pic...My Mind's made up Thanks all!
