4 Speed Clutch Rod - Not lining up with fork?!?!? #680551
04/26/10 10:16 AM
04/26/10 10:16 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
I'm putting everything back together on my 4-speed converted big block Challenger and have an alignment problem. The clutch rod is about 40 degrees (downward) off from where it connects to the clutch fork.
I am using all NEW E-Body specific parts parts to include:
Z-Bar
Aluminum Bellhousing
Clutch Fork
Clutch Rod
The Z-Bar is in its appropriate location and the pedal rod alignment is spot-on. The actuation works fine and the clutch feels nice and smooth.
Is it NORMAL for this rod to be off and not straight on the clutch fork?? Am I going to have problems down the road with this?
Thanks!
Steve
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: 4 Speed Clutch Rod - Not lining up with fork?!?!? [Re: Plum440] #680552
04/26/10 01:41 PM
04/26/10 01:41 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There are multiple Z-bars that are the same width, but have different tab alignment and length..
I had a similar problem with my 70RR which had the wrong Z-bar.
I would suggest that you talk with Wayne @ Brewers.. He has all of the Z-bars and knows Mopars very, very well..
937.698.4259
Just my $0.01..
