I'm putting everything back together on my 4-speed converted big block Challenger and have an alignment problem. The clutch rod is about 40 degrees (downward) off from where it connects to the clutch fork.
I am using all NEW E-Body specific parts parts to include:
Z-Bar
Aluminum Bellhousing
Clutch Fork
Clutch Rod
The Z-Bar is in its appropriate location and the pedal rod alignment is spot-on. The actuation works fine and the clutch feels nice and smooth.
Is it NORMAL for this rod to be off and not straight on the clutch fork?? Am I going to have problems down the road with this?
Thanks!
Steve
