Re: Help! starting 70 Challenger
[Re: rutro]
#680247
04/25/10 09:22 PM
04/25/10 09:22 PM
RapidRobert
Take a jumper wire w alligator clips on each end, then unplug the NSS wire from the "grn" terminal on the starter relay and jump the "grn" terminal (not the wire you removed from it) to ground and try it.
[Re: rutro]
#680251
04/26/10 09:29 PM
04/26/10 09:29 PM
Posts: 528 SW CO
HemiSportFury
SW CO
4 speed or auto? The starter relays are different to allow for the neutral safety switch on the auto transmission.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
