Help! starting 70 Challenger #680246
04/25/10 09:04 PM
04/25/10 09:04 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
So...I can start the car by using a push button from the engine compartment. But can't turn it over from the key on the column.
Use to be able to. I've since had unplug much of the dash wiring. But seems to be all plug up correctly.
When I turn the key I get a tingy sound, like an electrical sound.
I've replaced the starter relay...nothing different.
I have a new wiring harness for the neutral safety switch. Same switch in transmission when the car use to run.
Can anyone shed some light on my problem?
Thanks,
Mark
Re: Help! starting 70 Challenger [Re: rutro] #680247
04/25/10 09:22 PM
04/25/10 09:22 PM
Take a jumper wire w alligator clips on each end, then unplug the NSS wire from the "grn" terminal on the starter relay and jump the "grn" terminal (not the wire you removed from it) to ground and try it.
Re: Help! starting 70 Challenger [Re: rutro] #680248
04/26/10 11:33 AM
04/26/10 11:33 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Use a voltmeter to test for voltage to the relay with the key in the start position. Also check ALL your grounds. Your column needs that stupid little jumper ground wire to the stud holding the column up, the firewall needs a ground to the engine, and the starter relay needs a good ground to the fender well.
Re: Help! starting 70 Challenger [Re: Sixpak] #680249
04/26/10 12:51 PM
04/26/10 12:51 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
RapidRobert,
Thanks i will try tonight need to put bulkhead connector back in.
Sixpak,
Thanks, ground on the steering column? Is that part of the wiring harness or something I make up?
All good things to do tonight.
Re: Help! starting 70 Challenger [Re: RapidRobert] #680250
04/26/10 09:24 PM
04/26/10 09:24 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
RapidRobert
Thanks! Grounding terminal helped.
Just need to find out if switch is bad or the harness is messed up.
Sixpak
Put on a jumper wire as well.
THANKS!
Re: Help! starting 70 Challenger [Re: rutro] #680251
04/26/10 09:29 PM
04/26/10 09:29 PM
SW CO
HemiSportFury Offline
SW CO
4 speed or auto? The starter relays are different to allow for the neutral safety switch on the auto transmission.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
