440 sounds clattery #679923
04/25/10 03:28 PM
04/25/10 03:28 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Hello all got a question.
I bought a rebuilt 440 and recently installed and got it running. it is a bit of a mystery motor but I do know it has 10.5:1 compression and a 488 lift Elgin cam. All internals looked good with assembly lube etc.
It's got about 100 miles on it. When it idles it has a definite clatter to it almost like a diesel motor. Oil pressure is 50 lbs hot at idle and it runs at 180 degrees or less. Runs good overall.
The rockers are non adjustible stock type. Could the pushrods be too short? The rockers have some considerable side to side movement when the vavle is unloaded. Timing is 10 degrees Btdc. What else could cause this type of noise?
Thanks, let me know if any other info would be helpful.
Re: 440 sounds clattery [Re: HitIt] #679924
04/25/10 03:32 PM
04/25/10 03:32 PM
check a pair of lifters for how much preload they have
Re: 440 sounds clattery [Re: HitIt] #679925
04/25/10 05:01 PM
04/25/10 05:01 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
First, you pull the valve covers, one side at a time. Start'er up. See anything unusual? Take some heater hose with one end to your ear and the other end running along the valve train. Hear anything different in any particular cylinder(s)?
That will tell you if it's "upstairs" or "downstairs". Get back to us.
Re: 440 sounds clattery [Re: HitIt] #679926
04/25/10 05:08 PM
04/25/10 05:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
does it quiet down as RPMs go up??
Re: 440 sounds clattery [Re: Dodgem] #679927
04/25/10 05:43 PM
04/25/10 05:43 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
So basically if the preload on the lifter is not right what can I do with the stock rockers? Does that mean there is an incorrect pushrod length?
I can tell you that when the valves are unloaded the rocker and pushrod are quite loose with definite play in them. I thought the litters needed to pump up after the rebuild but that seems not to be the case. Everything in the head is getting plenty of oil.
And yes the noise is really only at idle. Thank you all for the help.
Re: 440 sounds clattery [Re: HitIt] #679928
04/25/10 06:51 PM
04/25/10 06:51 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
You answered your own question..
Not enough preload, IMHO.
Assuming the lifters are OK, you should upgrade to adjustable rockers but be careful of the Shanghai specials..
Just my $0.01..
Re: 440 sounds clattery [Re: Sinitro] #679929
04/25/10 07:17 PM
04/25/10 07:17 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Thanks for the opinion. So what's the consensus on a good setup that's not overly expensive? This is a street car.
Re: 440 sounds clattery [Re: HitIt] #679930
04/25/10 07:24 PM
04/25/10 07:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If it's only noisy at Idle I would suspect it may have roads style lifters that pump down for idle quality. if you hold it at 2500 and clattering disappears that's what i would suspect.
Re: 440 sounds clattery [Re: HitIt] #679931
04/25/10 07:43 PM
04/25/10 07:43 PM
West Coast, Canada
Dakota542 Offline
Dakota542  Offline
West Coast, Canada
What are the length of your pushrods? Maybe they are the wrong pushrods for a 440.
Does the rocker shaft have shims under it?
I'd be more interested in what the problem is, and then work on the best/cheapest way to correct it.
The ball-ball pushrods are available in almost any length you require.
Don't buy cheap roller rockers for a daily driver. Old school factory type adjustables - Cast Iron Ductile Mechanical Rocker Arm Package from Mopar Performance(P4120974) have been proven reliable for many years. The factory type adjustables use a cup-ball type pushrod, so you can add that to the price.
Re: 440 sounds clattery [Re: Dakota542] #679932
04/25/10 07:49 PM
04/25/10 07:49 PM
Exactly what I was thinking. I'd mockup an adjustable one to check & go from there. Not sure on the best procedure but might checkout www.hughesengines.com procedure
Re: 440 sounds clattery [Re: RapidRobert] #679933
04/25/10 09:09 PM
04/25/10 09:09 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Not sure on the length of the pushrods but I will check tomorrow.
The Rhodes lifter idea seems possible, but will they make noise when warmed up? Mine still makes the noise when warm.
What's the right range for a RB pushrod? Looking for an adjustible one but there are a few length options.
Thanks Again for the help.
Re: 440 sounds clattery [Re: HitIt] #679934
04/25/10 09:13 PM
04/25/10 09:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes Rhodes still make noise warm maybe worse?? but at a little rpm the quiet down.
listen to this guys
http://s143.photobucket.com/albums/r131/Skylark455/video/?action=view&current=100_3746.flv
what Rhoads says
http://www.rhoadslifters.com/Pages/FAQs.html
Re: 440 sounds clattery [Re: Dodgem] #679935
04/26/10 02:40 AM
04/26/10 02:40 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This may be overstating the obvious, but what about this: Check the orientation of the rocker arms? One time as a novice engine builder I accidently put mine together wrong. They are marked, but I had them flipped Intake for exhaust. This caused a rattle localized to that side of the engine. I returned to their proper order and the rattle went away.
Re: 440 sounds clattery [Re: Kern Dog] #679936
04/26/10 09:15 AM
04/26/10 09:15 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
that is something to check too they should be offset to the middle of each pair
Re: 440 sounds clattery [Re: HitIt] #679937
04/26/10 09:39 AM
04/26/10 09:39 AM
Commando1 Offline
Commando1  Offline
Everyone's coming up with a "fix" before it's been properly determined where the problem is.
Re: 440 sounds clattery [Re: Commando1] #679938
04/26/10 11:17 AM
04/26/10 11:17 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
just some things to look for would not be the first to slide the stamped rockers on the shaft wrong.
I think it has some kind of Rhoads type lifters (fast bleed lifter) if it quiets down as rpms come up.
Re: 440 sounds clattery [Re: Dodgem] #679939
04/26/10 11:36 AM
04/26/10 11:36 AM
Under My Car
Mopar_Country Offline
Under My Car
I would have to wonder what pins are in the connecting rods. If they are floating pins, that can create the diesel effect when first started and at idle. Does the noise go away when you accelerate?
Re: 440 sounds clattery [Re: Mopar_Country] #679940
04/26/10 12:59 PM
04/26/10 12:59 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Thanks for the help and ideas, the obvious ones are definitely of value too. This is my first mopar big block so I still am learning.
I have contacted the builder to see if he can give me any more information on the valvetrain setup. I’ll let you all know what comes out of that.
The thing I see at this point is excessive slop in the pushrods and rocker arms. I’ve done some research here, seems like they should have a bit of preload on them when unloaded, right?
I don’t see any shims or spacers under the rocker shaft mounts. I imagine the pushrods are just not the correct match for the lifters and stock rockers.
That video with the Rhodes lifter sounds pretty much like my engine at idle but I kinda don’t think that’s the issue.
Thanks again. Keep the ideas coming.
Re: 440 sounds clattery [Re: Kern Dog] #679941
04/26/10 01:02 PM
04/26/10 01:02 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
I'll take a look at that today, thanks for the idea. I *think* I looked at that and they seemed right but I wasn't specifically looking for that. Could be a couple are out of order like you say.
Appreciate the help very much.
Re: 440 sounds clattery [Re: HitIt] #679942
04/26/10 01:10 PM
04/26/10 01:10 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Also one other question - I am sure one of you would have suggested it if it were possible, but could this excessive slop in the valve train be a symptom of the cam going flat from a bad break-in?
I am sure I broke it in properly, but you just never know.
