Re: 440 sounds clattery
[Re: HitIt]
#679924
04/25/10 03:32 PM
04/25/10 03:32 PM
RapidRobert
check a pair of lifters for how much preload they have
[Re: HitIt]
#679928
04/25/10 06:51 PM
04/25/10 06:51 PM
Posts: 5,440 So Cal
Sinitro
So Cal
So basically if the preload on the lifter is not right what can I do with the stock rockers? Does that mean there is an incorrect pushrod length? I can tell you that when the valves are unloaded the rocker and pushrod are quite loose with definite play in them. I thought the litters needed to pump up after the rebuild but that seems not to be the case. Everything in the head is getting plenty of oil. And yes the noise is really only at idle. Thank you all for the help.
You answered your own question.. Not enough preload, IMHO. Assuming the lifters are OK, you should upgrade to adjustable rockers but be careful of the Shanghai specials..
Just my $0.01..
[Re: HitIt]
#679930
04/25/10 07:24 PM
04/25/10 07:24 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
So basically if the preload on the lifter is not right what can I do with the stock rockers? D And yes the noise is really only at idle. Thank you all for the help.
If it's only noisy at Idle I would suspect it may have roads style lifters that pump down for idle quality. if you hold it at 2500 and clattering disappears that's what i would suspect.
[Re: Kern Dog]
#679936
04/26/10 09:15 AM
04/26/10 09:15 AM
Dodgem
Ontario, Canada
This may be overstating the obvious, but what about this: Check the orientation of the rocker arms? One time as a novice engine builder I accidently put mine together wrong. They are marked, but I had them flipped Intake for exhaust. This caused a rattle localized to that side of the engine. I returned to their proper order and the rattle went away.
that is something to check too they should be offset to the middle of each pair
[Re: Kern Dog]
#679941
04/26/10 01:02 PM
04/26/10 01:02 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
I'll take a look at that today, thanks for the idea. I *think* I looked at that and they seemed right but I wasn't specifically looking for that. Could be a couple are out of order like you say.
Appreciate the help very much.
