Recurving M.P. Electronic Ignition.
#679757
04/25/10 10:27 AM
04/25/10 10:27 AM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
I know this has been touched on before. What is involved in recurving a Mopar Performance stock electronic distributor with a chrome box? Is there a kit? Is it just replacing the spring in the distributor? Is it worth it? Who sells the kit if there is one? I know the sell the springs. What else? Thanks Rob
If you can't be smart.....don't be stupid!
Re: Recurving M.P. Electronic Ignition.
[Re: Dougsmopars]
#679760
04/25/10 12:16 PM
04/25/10 12:16 PM
Posts: 1,191 imperial mo.
stickman
imperial mo.
Could you guys post the contact info & part # of the kits.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
[Re: Dougsmopars]
#679763
04/25/10 02:37 PM
04/25/10 02:37 PM
yellow sixpack
Long Island NY
Thanks fellas. I guess you can use this kit all types of distributors as long as you know what you have. It not application specific like it states in description.
[Re: yellow sixpack]
#679764
04/25/10 02:45 PM
04/25/10 02:45 PM
Posts: 1,672 Virginia
HemiStan
Virginia
It's not that difficult to do yourself. I do all of my own. It is a bit of trial and error without a distributor machine but that's OK. Check out this article by Steve Dulcich. Very good article. Recurving Distributor Stan
#679767
04/25/10 09:38 PM
04/25/10 09:38 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Actually Mopar sells the kit.. Includes springs and 2 degree key set. #P5153446Just my $0.01..
[Re: CR8CRSHR]
#679768
04/25/10 09:40 PM
04/25/10 09:40 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I opted to go with the 4 seconds flat/FBO set up. After talking with Don, I am now thoroughly convinced that his set up is the only way to go....
it's great to know that you can curve it with a kit, BUT you still need to know what you are curving it to. Don is quite knowledgable in this area, as are others
[Re: Dougsmopars]
#679774
05/01/10 10:03 AM
05/01/10 10:03 AM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
I'm sure Don does wonderful work. For an all out race car i would consider sending my dizzy out. For a street car its not rocket sicience. Find what car wants for initial. Total no more then 38. No big deal. 30 bucks for a kit and a little elbow grease. Don ain't recurving them for 30 bucks.
OK I'll give you that. But I would rather have it done right the first time and not have to re-do it because I was not as thorough as Don is. At this point in my life it is far easier to spend the $$$s. Besides his expertise is unsurpassed...
[Re: CR8CRSHR]
#679775
05/01/10 10:14 AM
05/01/10 10:14 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
It's not hard to do at all. I did mine in the garage,,,took about 1/2 hour,,,, Just need to figure out what your initial and total timing is going to be. Weld or file the slots in the plate,,,,, Trial and error on the springs,,,etc,,,, cost = about nothing,,,perhaps some springs,,,plus i learned ALOT about my car,,,how to tear into the distributor and repair it,,, Don does great work,,,but for $149 to "curve" it,,,i would try it on your own first,,,,
[Re: 69CHARGERMD]
#679776
05/01/10 10:39 AM
05/01/10 10:39 AM
RapidRobert
X2. Especially once you figure out how to get the clip out easily. Just do em in order: initial/total/springs/vac adv
