Recurving M.P. Electronic Ignition. #679757
04/25/10 10:27 AM
04/25/10 10:27 AM
Long Island NY
yellow sixpack Offline OP
Long Island NY
I know this has been touched on before. What is involved in recurving a Mopar Performance stock electronic distributor with a chrome box? Is there a kit? Is it just replacing the spring in the distributor? Is it worth it? Who sells the kit if there is one? I know the sell the springs. What else?
Rob
If you can't be smart.....don't be stupid!
Re: Recurving M.P. Electronic Ignition. [Re: yellow sixpack] #679758
04/25/10 10:45 AM
04/25/10 10:45 AM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Go to Summit or Jegs. Mallory has a re curve kit. Mallory builds the MP electronic dizzy. Comes with a selection of springs and gauges to set the slots. Nice little kit. Makes re curving very simple. Yes it's worth it if you have some modifcations done to your motor. Increasing initial timing can make a huge difference in performence. Total timing should remain around 36 to 38 degrees. To do this you must recurve the dizzy.
Re: Recurving M.P. Electronic Ignition. [Re: Dougsmopars] #679759
04/25/10 12:13 PM
04/25/10 12:13 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I opted to go with the 4 seconds flat/FBO set up. After talking with Don, I am now thoroughly convinced that his set up is the only way to go....
Re: Recurving M.P. Electronic Ignition. [Re: Dougsmopars] #679760
04/25/10 12:16 PM
04/25/10 12:16 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Could you guys post the contact info & part #
of the kits.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: Recurving M.P. Electronic Ignition. [Re: stickman] #679761
04/25/10 12:36 PM
04/25/10 12:36 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Re: Recurving M.P. Electronic Ignition. [Re: stickman] #679762
04/25/10 12:43 PM
04/25/10 12:43 PM
Dougsmopars Offline
Dougsmopars  Offline
Re: Recurving M.P. Electronic Ignition. [Re: Dougsmopars] #679763
04/25/10 02:37 PM
04/25/10 02:37 PM
Long Island NY
Long Island NY
Thanks fellas. I guess you can use this kit all types of distributors as long as you know what you have. It not application specific like it states in description.
Re: Recurving M.P. Electronic Ignition. [Re: yellow sixpack] #679764
04/25/10 02:45 PM
04/25/10 02:45 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
It's not that difficult to do yourself. I do all of my own. It is a bit of trial and error without a distributor machine but that's OK. Check out this article by Steve Dulcich. Very good article.
Recurving Distributor
Stan
Re: Recurving M.P. Electronic Ignition. [Re: yellow sixpack] #679765
04/25/10 02:47 PM
04/25/10 02:47 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
The MP distributors built by Mallory use a YH mechanical advance.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Recurving M.P. Electronic Ignition. [Re: RobbMc] #679766
04/25/10 08:48 PM
04/25/10 08:48 PM
Dougsmopars Offline
Dougsmopars  Offline
Yes they do in deed. Summit number 850535 is the kit for YH dizzy and is complete kit with spring asortment.
Re: Recurving M.P. Electronic Ignition. [Re: yellow sixpack] #679767
04/25/10 09:38 PM
04/25/10 09:38 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Actually Mopar sells the kit..
Includes springs and 2 degree key set.
#P5153446
Just my $0.01..
Re: Recurving M.P. Electronic Ignition. [Re: CR8CRSHR] #679768
04/25/10 09:40 PM
04/25/10 09:40 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
it's great to know that you can curve it with a kit, BUT you still need to know what you are curving it to. Don is quite knowledgable in this area, as are others
Re: Recurving M.P. Electronic Ignition. [Re: dave571] #679769
04/25/10 09:48 PM
04/25/10 09:48 PM
Dougsmopars Offline
Dougsmopars  Offline
I'm sure Don does wonderful work. For an all out race car i would consider sending my dizzy out. For a street car its not rocket sicience. Find what car wants for initial. Total no more then 38. No big deal. 30 bucks for a kit and a little elbow grease. Don ain't recurving them for 30 bucks.
Re: Recurving M.P. Electronic Ignition. [Re: Dougsmopars] #679770
04/27/10 09:00 AM
04/27/10 09:00 AM
Long Island NY
Long Island NY
http://www.summitracing.com/parts/DCC-2932675/
Going with these according to Mopar Tech line these replace the stock springs that come in the distributor in the Mopar performance electronic dist. kit.
Re: Recurving M.P. Electronic Ignition. [Re: yellow sixpack] #679771
04/27/10 09:54 AM
04/27/10 09:54 AM
What Dougsmopars said: grab most any electronic dist as they dont wear the bushings like the points ones do because there's no side loading from opening the points. Take it apart/clean w solvent/dry/lube/toss the heavy spring w the long loop/keep the oe light spring then drive out the roll pin and add washers to reduce the end play to almost zero and add (1) of the light springs from the aforementioned MP Summitt cellophane kit for a start. Find your ideal initial (vac gauge method has been touted) then shorten the slots for 36-38 total then play w the springs keeping it just under the pinging point @ WOT no matter where (RPM) that makes the slots max out at then plug in the vac adv (if used) & play w it. The spring experimentation is what Don will do and I have spoken w him and I was impressed also and w his knowledge he'll get you close but you can get it even closer/near perfect for your eng plus the temp/humidity he cannot forsee but the only caveat being is that it takes multiple dissassembly of the dist to get the spring combo dead on. You will get good at taking that little clip out and there's the Mallory/MP externally adjustable units (havent seen/used one yet) here's a spring chart that may help/motivate you though the 3 springs in the Crane kit are no longer available (there must be others somewhere) and only the col on the left is important as depending on your idle rpm you want it lower than the advance start point. Just remember to do each one in order and that the vac adv stays capped off until the last.
Re: Recurving M.P. Electronic Ignition. [Re: RapidRobert] #679772
05/01/10 07:12 AM
05/01/10 07:12 AM
5thAve Offline
5thAve  Offline
Ive had electronic distributors with worn bushings.
I bought the Mallory kit a couple years ago for mine. Summitt always wants too much for shipping things here. Got it from a local speed shop instead
Re: Recurving M.P. Electronic Ignition. [Re: 5thAve] #679773
05/01/10 10:01 AM
05/01/10 10:01 AM
5th ave, do the springs in that kit fit an old style electronic dist? the crane kit in the chart I posted above is not available anymore.
Re: Recurving M.P. Electronic Ignition. [Re: Dougsmopars] #679774
05/01/10 10:03 AM
05/01/10 10:03 AM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
OK I'll give you that. But I would rather have it done right the first time and not have to re-do it because I was not as thorough as Don is. At this point in my life it is far easier to spend the $$$s. Besides his expertise is unsurpassed...
Re: Recurving M.P. Electronic Ignition. [Re: CR8CRSHR] #679775
05/01/10 10:14 AM
05/01/10 10:14 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
It's not hard to do at all.
I did mine in the garage,,,took about 1/2 hour,,,,
Just need to figure out what your initial and total timing is going to be.
Weld or file the slots in the plate,,,,,
Trial and error on the springs,,,etc,,,,
cost = about nothing,,,perhaps some springs,,,plus i learned ALOT about my car,,,how to tear into the distributor and repair it,,,
Don does great work,,,but for $149 to "curve" it,,,i would try it on your own first,,,,
Re: Recurving M.P. Electronic Ignition. [Re: 69CHARGERMD] #679776
05/01/10 10:39 AM
05/01/10 10:39 AM
X2. Especially once you figure out how to get the clip out easily. Just do em in order: initial/total/springs/vac adv
