Rocker arm adjustments #67970
06/05/08 10:01 AM
06/05/08 10:01 AM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Putting on adjustable rockers,
How do I go about setting these up?
Can I do both sides or one side at a time?
They get adjusted when the valves are closed Correct? How do I tell if the valves are closed etc..
Re: Rocker arm adjustments [Re: DAMOPARS] #67971
06/05/08 10:19 AM
06/05/08 10:19 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
look on Comp Cams web site they tell how to set them up
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Rocker arm adjustments [Re: DAMOPARS] #67972
06/05/08 12:34 PM
06/05/08 12:34 PM
Sterling Heights, Michigan
My340Duster Offline
super gas
My340Duster  Offline
super gas
Adjust them to zero lash and then turn in 3/4 of a turn and lock them down. Adjust them according to the chart attached here.
Re: Rocker arm adjustments [Re: My340Duster] #67973
06/05/08 01:33 PM
06/05/08 01:33 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Will that chart work the same for a BB?
Re: Rocker arm adjustments [Re: DAMOPARS] #67974
06/05/08 04:52 PM
06/05/08 04:52 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
i dont think so, and thats strange...
TDC on a RB hits 2+7 on int, and 4 +8 on the exh. that is not congruent with that chart.
Re: Rocker arm adjustments [Re: DAMOPARS] #67975
06/05/08 05:03 PM
06/05/08 05:03 PM
indiana
marks69 Offline
marks69  Offline
indiana
Start at one cylinder and finish the intake and exhaust valve both before moving on.Turn your motor over clockwise, when the exhaust valve starts just starts to open stop and adjust the intake valve.(adjust to whatever lash is required whether hydraulic or solid).Next continue to turn the motor clockwise watching the intake valve of the same cylinder. When the intake valve opens and almost completely shuts stop and adjust the exhaust valve. Now continue to the next cylinder. This is the proper way to lash your valves according to comp cams and many other manufacturers.
Re: Rocker arm adjustments [Re: marks69] #67976
06/05/08 10:32 PM
06/05/08 10:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
have used this method since it was taught to me 30 years ago
