64 dodge polara front end rebuild #679306
04/24/10 08:25 PM
04/24/10 08:25 PM
strum, WI
demonbeekeepr Offline OP
strum, WI
Was looking for some feedback on rebuilding front end on 64 dodge polara. I was wondering what kits are available and from who and what is the most bang for the buck. Looking to add sway bar was wondering if newer b-bodies would work. Looking to do a complete rebuild went to local supplier seemed pretty high buying stuff seperate. I was just wondering who has good luck do theres. thanks Roger
Re: 64 dodge polara front end rebuild [Re: demonbeekeepr] #679307
04/24/10 09:45 PM
04/24/10 09:45 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Just did ours over the winter. Bought everything from Rock Auto. We did a 64 Plymouth from the Rock Auto/Advance Auto parts (whichever was cheaper) and a 73 Challenger from PST. The individual prices from Rock Auto and Advance Auto Parts beat the PST price by a good margin.
If you want a sway bar you will probably need lower control arms from a later B/E body that came with one as they have the bracket for the end links. If you are replacing lower control arm bushings you only want to do this once. It can be a pain. The front end tools from Mancini make it alot easier.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 64 dodge polara front end rebuild [Re: Dads426] #679308
04/24/10 09:48 PM
04/24/10 09:48 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
we just did my 66 and most of the parts i got off Ebay, MOOG made in the usa old stock, I have the tool to change the upper control arm bushings if you want to borrow it, it removes and installs the bushings....I think I have a spare pare of new lower control arm bushings..
Re: 64 dodge polara front end rebuild [Re: Joesixpack] #679309
04/25/10 07:20 AM
04/25/10 07:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Use either Moog or TRW parts.Id also install Moog Offset upper bushings as most old Mopars you cant get enough caster without them.Rocky
Chrysler Firepower
Re: 64 dodge polara front end rebuild [Re: therocks] #679310
04/25/10 07:47 AM
04/25/10 07:47 AM
strum, WI
strum, WI
i got a 73 dart disc brake system im putting in can i use the polara upper control arms or do i have to use the darts?
Re: 64 dodge polara front end rebuild [Re: demonbeekeepr] #679311
04/25/10 07:48 AM
04/25/10 07:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The Polara will fit.Rocky
Chrysler Firepower
Re: 64 dodge polara front end rebuild [Re: therocks] #679312
04/25/10 08:11 AM
04/25/10 08:11 AM
strum, WI
strum, WI
any good places to deal with to get these parts thanks for all the help!
Re: 64 dodge polara front end rebuild [Re: demonbeekeepr] #679313
04/25/10 08:15 AM
04/25/10 08:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I bought a bunch of TRW at Advanced.They quit making it but they did have some in stock.Our shop was next to them and I got good discounts.They also carry Moog but the TRW if you can get it is just as good and a bit cheaper.Rocky
Chrysler Firepower
Re: 64 dodge polara front end rebuild [Re: demonbeekeepr] #679314
04/25/10 09:38 AM
04/25/10 09:38 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I got the sway bar fo my 63 Plymouth from Just Suspension. 118.00 to my door. justsuspension.com.
Two angle brackets bolt to lower shock bolts,have to drill holes in K frame for mounting brackets,I took the meassrements off my RR for them,worked fine. This was in 07 so price may be higher now.
Bar was 99.00 shipping 19.00. If you're worried about weight bar is heavy.
