Hughes Whiplash #678973
04/24/10 04:41 PM
04/24/10 04:41 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I am installing a Whiplash cam im my Challenger and was wondering if I can use lifters ( http://www.summitracing.com/parts/SUM-HT2011/Application/?prefilter=0 )I have that I bought from Summit? The lifters are new and are $2.50 a piece cheaper then Hughes is selling them for. Is there a difference int them?
Re: Hughes Whiplash *DELETED* [Re: Shatar4] #678974
04/24/10 07:30 PM
04/24/10 07:30 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Post deleted by Shatar4
Re: Hughes Whiplash [Re: Shatar4] #678975
04/24/10 07:41 PM
04/24/10 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I expect hydraulic lifters are pretty much interchangable for the same application. Look at the specs of each and go from there.
Re: Hughes Whiplash [Re: stumpy] #678976
04/24/10 07:42 PM
04/24/10 07:42 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
as long as they spec out the same use them.
Re: Hughes Whiplash [Re: Shatar4] #678977
04/27/10 10:11 AM
04/27/10 10:11 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
The lifters will physically interchange. The only caveat I would offer is that there has been quite a bit of trouble with import lifters coming apart and/or being soft. The lifters we sell are made by HyLift Johnson in Michigan. We do not import any lifters. No matter where you buy them, I would suggest being sure they are not coming from Mexico or China etc.....
Thanks, Kevin
Re: Hughes Whiplash [Re: Hughes] #678978
04/27/10 01:12 PM
04/27/10 01:12 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Hey Kevin ... just curious .. if you have a known-quality USED lifter that has a nice crown - can these lifters be used on a new cam?
Re: Hughes Whiplash [Re: dOrk !] #678979
04/27/10 03:23 PM
04/27/10 03:23 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
If you really, really check them close, I know guys re-use them. As a cam supplier... I have to suggest that you always use new lifters.
Kevin @ Hughes
