Help! Car stalls when I "hit it" in burnout & on 2 step #678791
04/24/10 11:10 AM
04/24/10 11:10 AM
Penna
70satelliteguy Offline OP
Penna
The car stalled on the line last night right when I went on the 2 step. Had to be pushed off the line. Also had a little fire in the hoodscoop which was easily put out by just blowing into the scoop. It also seems like it wants to do this when I first hit it in the burnout box. The rest of the night I kinda "leaned into the throttle" gradually to prevent this from happening and that worked but it cost me in the second round(late!!!) doing this on the 2 step .
Should I go larger(carb too lean) on the shooters to cure this or smaller(carb too rich)?
Anyone have this happen to them and found a cure? Shure would appreciate some help!
Thanks Mike
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: 70satelliteguy] #678792
04/24/10 11:20 AM
04/24/10 11:20 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Haveing a similar symptom With the 72 and so far nothing I have done with the squirters has seemed to make a difference.
I'll be watching this one as well
Re: Help! Car stalls when I "hit it" in burnout & on 2 step *DELETED* [Re: WILD BILL] #678793
04/24/10 11:33 AM
04/24/10 11:33 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
Post deleted by hemiparts
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: hemiparts] #678794
04/24/10 11:48 AM
04/24/10 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Both of you should try fattening up your idle screws
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: MR_P_BODY] #678795
04/24/10 12:15 PM
04/24/10 12:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and check the pump cams, some have a delay in them. the blue or brown cams may help. after you are sure you have no timing or ignition issues.
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: Quicktree] #678796
04/24/10 12:40 PM
04/24/10 12:40 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
had the same issue...changed pump cam and all was good.
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: 70satelliteguy] #678797
04/24/10 01:21 PM
04/24/10 01:21 PM
Penna
Penna
"Both of you should try fattening up your idle screws"
Thanks for the reply Mr. P body.
Could you elaborate on how fattening up the idle will affect the "hit"
Thanks Mike
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: 70satelliteguy] #678798
04/24/10 01:35 PM
04/24/10 01:35 PM
Thanks Mike
I'll try, when your lean on the idle circuit it will want to die due to a lack of suffeceint fuel to keep the motor running, you can try a very small wire in the idle bleeds, all of them first and see if that fixes it. If it does you can remove the old bleeds and install new smaller ones or use some epoxy to fill them and then drill them smaller. The other thing is to properly adjust the accelerator pump screw on the accelertor pump arm to Holley specs That is with the throttle at wide open throttle you should be able to slide a .015 feeler gauge in easily between the accelerator pump screw and the pump lever attached to the float bowl Most carbs. are not even close to that spec
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: Cab_Burge] #678799
04/24/10 04:56 PM
04/24/10 04:56 PM
UK
602heavy Offline
602heavy  Offline
UK
Is the motor still cold in the bleach box? , fire through the carb is a lean condition , will also happen when too much timing is pulled (misfire in cap)
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: 70satelliteguy] #678800
04/24/10 06:01 PM
04/24/10 06:01 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
When mine started doing that it was just old pump diaphragms. They get stiff when they get old and don't retract fully, reducing volume. New ones are much more flexible and totally fixed it. The used Holley 9377 I bought on ebay last winter had such stiff diaphragms that you couldn't even open the throttles fully. Seller said he was using it last summer It's otherwise a virgin carb, I don't think he knew how to work on it so just bought another.
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: 602heavy] #678801
04/24/10 06:16 PM
04/24/10 06:16 PM
Penna
Penna
"Is the motor still cold in the bleach box? , fire through the carb is a lean condition , will also happen when too much timing is pulled (misfire in cap)
Car was fully warmed up in the box and on the line! Has a brand new MSD Pro billet Dist. with all timing in by about 2000
"When mine started doing that it was just old pump diaphragms"
Carb was brand new last year but did sit off of motor all winter and was dry!
"old bleeds and install new smaller ones "
will check on this also!!!
Mike
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: MR_P_BODY] #678802
04/24/10 07:55 PM
04/24/10 07:55 PM
North Branch, MI, USA
notchbackcuda Offline
I agree, seems like the idle mixture has to be rich enough to carry the engine through the sudden throttle opening. The fuel from the squirters doesn't arrive quick enough. Back out the low speed screw 1/2 turn or so and it should help, especially if the air is cool.
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: MR_P_BODY] #678803
04/24/10 08:01 PM
04/24/10 08:01 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Hey Mike, remember me?
I'm the one who screwed that up so bad you had to come over and fix it right
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: WILD BILL] #678804
04/24/10 08:07 PM
04/24/10 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... is it still working
Re: Help! Car stalls when I "hit it" in burnout & on 2 step [Re: MR_P_BODY] #678805
04/24/10 08:32 PM
04/24/10 08:32 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Save for this slight hic up yes
So long as I don't touch it
When's the next time we'll be at the same place?
