Rubber brake line? #678318
04/23/10 03:20 PM
04/23/10 03:20 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Im starting to run the new brake lines and having trouble locating the right line...
I need a part number for the soft rubber line that comes off the frame or chassis that runs to the Y-Block mounted on the rearend housing. This line is slightly lager than the lines running to each side of the axle off the Y-Block...The small lines are 3/16 and looks like the larger line I need may be 1/8 inch Inverted flare but not 100% sure..
The parts store could only pull up a complete line with the Y block attached for like $40...
I thought I might need a longer than normal line, maybe off a 4x4 truck or something.
Re: Rubber brake line? [Re: Bob_Coomer] #678319
04/23/10 10:31 PM
04/23/10 10:31 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I used one on the rear of the 64 that's from a mid 90s ford truck. It's a couple inches longer. Got a vent tube bolt from the same year truck and drilled and tapped the housing. It's on Dana 60 and didn't have vent in it yet. Its still in the process.
Re: Rubber brake line? [Re: Todd] #678320
04/23/10 10:59 PM
04/23/10 10:59 PM
Rock Springs
Rock Springs
Guess I will just buy the hose a Y block assembly...Its a shame you cant get the correct parts any more, you stuck with buying inferior aftermarket China Junk....
Thats what Advance and Autozone carries now....China Junk...If the part was made over here and at one time had good parts, all thats left is the base part with new china junk.
And what happened to old school parts guys...Where you could walk into the store say hey, I need a fitting for my Master Cylinder that is a 5/16 inverted flare TO a 3/16 inverted flare..they say OK..walk back and grab one off the shelf....
Now they turn and look at the computer, and say whats that for?
Re: Rubber brake line? [Re: Bob_Coomer] #678321
04/23/10 11:17 PM
04/23/10 11:17 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I agree totaly but what else can we do? Those sure were the good ole days. Some parts guys don't even know what your talking about unless they can find it on the computer.
Re: Rubber brake line? [Re: Todd] #678322
04/24/10 12:19 AM
04/24/10 12:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I did the same thing when I needed a rear flex line, took in my old crusty one to NAPA, told them I wanted one longer, solved the problem of what does it fit ? by saying just go and look what you have cause I don't know what it fits. That's the worse part of getting old car parts, the stupid counter guy doesn't know what a part is, just a # in the computer.
Re: Rubber brake line? [Re: rowin4] #678323
04/24/10 06:03 AM
04/24/10 06:03 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the stock black lines are junk. summit or jegs has a braided flex line
Re: Rubber brake line? [Re: Quicktree] #678324
04/24/10 12:02 PM
04/24/10 12:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I kind of think yea.
Don't even get me started on parts counter guys.
With a '65 Dart that has 73-76 A body front brakes , large bolt pattern rear axles and is soon to be an R-3 / W-9 ............ I can't even explain to them what I have.
Heck....... I was replacing the rear brake line on a Mazda pick up with bulk line and unions......I showed the gal at NAPA what I had and what I wanted , then volunteered to go back and get it myself. ( I have been going to this store for nearly 20 years , but she is new )
She got all huffy and said " I'll get it " and sent me home with the wrong fitting.
So I am back there 20 minutes later and she still had to be right.
I am old enough to remember when parts guys were also car guys.
But you can't get a good car guy for 8.00 an hour anymore.
Re: Rubber brake line? [Re: tubtar] #678325
04/24/10 12:31 PM
04/24/10 12:31 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
The thing is us type are 1 in a thousand...they carry tens of thousands of parts.....autozone/advance are not parts store for the musclecar type....maybe try out your local carquest type store...I've got one about 5 mins away that know their stuff.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Rubber brake line? [Re: Bob_Coomer] #678326
04/24/10 02:09 PM
04/24/10 02:09 PM
Try a big NAPA store Bob, if you can take the old one with you
