FRONT TIRES #678205
04/23/10 02:07 PM
04/23/10 02:07 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Is there a difference in racing when you use a 26" tall front tire to a 28" tall front tire??
Re: FRONT TIRES [Re: MIKES_DUSTER] #678206
04/23/10 02:11 PM
04/23/10 02:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Roll out is different which can/will change your reaction
time if you leave the same for both
Re: FRONT TIRES [Re: MR_P_BODY] #678207
04/23/10 02:14 PM
04/23/10 02:14 PM
tboomer Offline
tboomer  Offline
Raff is right...When I went from the taller tire to a 26" MT...It took time to find the sweet spot on my RT....
Re: FRONT TIRES [Re: MR_P_BODY] #678208
04/23/10 02:15 PM
04/23/10 02:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also the taller front tires will help transfer weight
better(your moving the engine up higher so its closer
to the CG height) if you dont lower the body back
down with the bars or springs
Re: FRONT TIRES [Re: MR_P_BODY] #678209
04/23/10 02:19 PM
04/23/10 02:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
taller tire will lower your et. more rollout thru the beams
Re: FRONT TIRES [Re: MIKES_DUSTER] #678210
04/23/10 02:30 PM
04/23/10 02:30 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
All of the above plus you'll have to trim alot off the front of the wheel opening to get a 28 inch tire to work in a Duster fender...don't ask me how I know
Re: FRONT TIRES [Re: actionange] #678211
04/23/10 05:10 PM
04/23/10 05:10 PM
THANKS for all the info guys!!!! And Ange,I would like to know!!!!
I have M/T 26"x4.5" and was thinking of going up to 27" or 28".
Re: FRONT TIRES [Re: MIKES_DUSTER] #678212
04/23/10 07:43 PM
04/23/10 07:43 PM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Just watch out for the tire rubbing the fender lip
Re: FRONT TIRES [Re: Dartwizer] #678213
04/23/10 08:09 PM
04/23/10 08:09 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'm partial to 7.10-15 Moroso Drag Specials. They require trimming the front edge. I've always wondered, if a different offset front wheel would help.
Re: FRONT TIRES [Re: Leigh] #678214
04/23/10 11:25 PM
04/23/10 11:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mr three
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: FRONT TIRES [Re: MIKES_DUSTER] #678215
04/23/10 11:55 PM
04/23/10 11:55 PM
I put a set of 710x15 Moroso on my 1971 DusterHad 26 inch tall M/T front runners)(that use to have cherry fenders, not any more ) they rubbed on the front lower corners when turning and on the bolts in the rear that held the splash pans on I tried both offsets for the front wheels and still had to trim the front edge and removed the offending bolts and bend the tabs in raising the front end some may have helped but I was at a reace when I put them on, once I got in the car the problem got worst, I wonder why 260 lbs maybe
