Re: FRONT TIRES
[Re: MIKES_DUSTER]
#678206
04/23/10 02:11 PM
04/23/10 02:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is there a difference in racing when you use a 26" tall front tire to a 28" tall front tire??
Roll out is different which can/will change your reaction time if you leave the same for both
Re: FRONT TIRES
[Re: MR_P_BODY]
#678208
04/23/10 02:15 PM
04/23/10 02:15 PM
MR_P_BODY
Also the taller front tires will help transfer weight better(your moving the engine up higher so its closer to the CG height) if you dont lower the body back down with the bars or springs
Re: FRONT TIRES
[Re: MR_P_BODY]
#678209
04/23/10 02:19 PM
04/23/10 02:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
taller tire will lower your et. more rollout thru the beams
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
