Re: Can you/do you run QTP tires tubeless???? [Re: Ron Silva] #678172
04/23/10 07:34 PM
04/23/10 07:34 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Hate to see you do a burn out with the rim instead of the tire. Or would that be called a burn in?
Re: Can you/do you run QTP tires tubeless???? [Re: Ron Silva] #678173
04/23/10 07:39 PM
04/23/10 07:39 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I ran mine tubeless also. Mine was a heavy street car that ran 9's with these tires. They NEVER leaked any air. I did prep them with a lot of soap on the interior of the tire. I poured it in and coated the entire inside. When it dried and some of the soap puddled on the bottom, I moved the soap around until it was all absorbed by the tire.
Eventually the tires got used up. Had them for years and sat in the garage over long winters without lossing air. BTW, these were also screwed to the rims.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
383man [Re: turbobitt] #678174
04/24/10 02:05 AM
04/24/10 02:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I dont run tubes. He still uses QTP Hoosier's and I am using the Hoosier radial slicks. I can tell you they never leak air. They both sat all winter and did not drop any air. They hold air good. Ron
Re: 383man [Re: 383man] #678175
04/24/10 01:23 PM
04/24/10 01:23 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
I usually use tubes and screws, but last year I had a few runs left in my old QTP's and decided to try a new pair tubeless w/o screws in a spare set of wheels. I just checked pressure this week and had lost no air all winter. I used Palmolive dish soap in them, and NAPA bead sealer on the beads.
