Re: Can you/do you run QTP tires tubeless????
[Re: Ron Silva]
#678173
04/23/10 07:39 PM
04/23/10 07:39 PM
Posts: 759 Southington Ct.
turbobitt
Southington Ct.
I ran mine tubeless also. Mine was a heavy street car that ran 9's with these tires. They NEVER leaked any air. I did prep them with a lot of soap on the interior of the tire. I poured it in and coated the entire inside. When it dried and some of the soap puddled on the bottom, I moved the soap around until it was all absorbed by the tire. Eventually the tires got used up. Had them for years and sat in the garage over long winters without lossing air. BTW, these were also screwed to the rims. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
