TTi header touching passenger side torsion bar
#677991
04/23/10 08:42 AM
04/23/10 08:42 AM
Posts: 447 Knoxville, TN
YGBSM
Knoxville, TN
I'm installing a full TTi exhaust system. 1 7/8" headers on a 440 with the Mopar 383/440 aluminum cylinder head (also known as Street Stage VI)- these have stock port locations. The driver's side clears the torsion bar fine, the passenger side rubs up against the torsion bar. Anyone had this issue? The TTi system is a quality piece (I'm not knocking them because there's always the possibility I did something wrong) but I guess I expected it to fit perfectly.
1968 Charger R/T 2015 Charger R/T Scat Pack 2017 Durango Citadel
Re: TTi header touching passenger side torsion bar
[Re: 540challenger]
#677993
04/23/10 09:19 AM
04/23/10 09:19 AM
YGBSM
Knoxville, TN
Thanks. The motor mounts are brand new (I'm doing an engine swap and switched to headers at the same time).
[Re: Jeremiah]
#677995
04/23/10 09:35 AM
04/23/10 09:35 AM
YGBSM
Knoxville, TN
Yes, the regular Stage VI heads do have raised ports. These are a variation called street stage VI or 383/440 aluminum cylinder head, part number P4876311 (discontinued). They have stock port locations.
[Re: YGBSM]
#677997
04/23/10 12:16 PM
04/23/10 12:16 PM
Posts: 3,916 usa
lewtot184
usa
i think the '311 head has the intake ports in the stock location but not the exhaust. find an iron head and do some measuring.
[Re: YGBSM]
#678000
04/24/10 02:33 PM
04/24/10 02:33 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Schumacher makes a shim kit, EZ to install if you need a slight height adjustment for header clearance.. No need to start bending in the tubes.. Just my $0.01...
[Re: YGBSM]
#678001
04/25/10 02:27 PM
04/25/10 02:27 PM
BradH
No, they don't. The 4876311's exhaust port location is identical to a standard Stage VI, which means it's about .4" wider and .4" higher than an OEM head's exhaust port. That's why you have clearance issues w/ the torsion bar.
[Re: BradH]
#678002
04/25/10 03:29 PM
04/25/10 03:29 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Measure your crankshaft centerline in relation to the K-frame etc just like they tell you in the directions. I have the locking Mighty mounts and they raise the engine slightly. My passenger side 2" TTi is close, so I wrapped the torsion bar with heat insulation.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#678004
04/25/10 05:54 PM
04/25/10 05:54 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Yeah I would make sure the engine is sitting in there according to TTI specs. Chrysler was real sloppy on the k-frames back in the day so you don't know where that engine is until you measure.
