TTi header touching passenger side torsion bar #677991
04/23/10 08:42 AM
04/23/10 08:42 AM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
I'm installing a full TTi exhaust system. 1 7/8" headers on a 440 with the Mopar 383/440 aluminum cylinder head (also known as Street Stage VI)- these have stock port locations. The driver's side clears the torsion bar fine, the passenger side rubs up against the torsion bar.
Anyone had this issue? The TTi system is a quality piece (I'm not knocking them because there's always the possibility I did something wrong) but I guess I expected it to fit perfectly.
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #677992
04/23/10 09:13 AM
04/23/10 09:13 AM
NY usa
540challenger Offline
NY usa
Check for worn mounts and if everthing looks good, I would loosen the passenger side mount and jack the motor up and tighten down the mount and see if that helps out.
Re: TTi header touching passenger side torsion bar [Re: 540challenger] #677993
04/23/10 09:19 AM
04/23/10 09:19 AM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Thanks. The motor mounts are brand new (I'm doing an engine swap and switched to headers at the same time).
1968 Charger R/T
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #677994
04/23/10 09:28 AM
04/23/10 09:28 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I thought the Stage 6 heads have raised exhaust ports? Could that be causing the clearance issue?
Re: TTi header touching passenger side torsion bar [Re: Jeremiah] #677995
04/23/10 09:35 AM
04/23/10 09:35 AM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Yes, the regular Stage VI heads do have raised ports. These are a variation called street stage VI or 383/440 aluminum cylinder head, part number P4876311 (discontinued). They have stock port locations.
1968 Charger R/T
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #677996
04/23/10 09:42 AM
04/23/10 09:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had edelbrocks on an rb 68 b body, and had the same close fit on right side. It didn't hit but was darn close.
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #677997
04/23/10 12:16 PM
04/23/10 12:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think the '311 head has the intake ports in the stock location but not the exhaust. find an iron head and do some measuring.
Re: TTi header touching passenger side torsion bar [Re: buildanother] #677998
04/23/10 10:24 PM
04/23/10 10:24 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Mine did hit - 383 swapped into a Duster - had to it a bit.
Ride eternal, shiny and chrome
Re: TTi header touching passenger side torsion bar [Re: DirectSubjection] #677999
04/24/10 12:01 AM
04/24/10 12:01 AM
midwest
I
intragration Offline
I
midwest
I have Hooker 1 7/8s on a 440 in my '74 'Cuda. This setup was in the car before with no problems. I put the headers in myself way back when. Took everything apart, put everything back together, suddenly the header hits the passenger torsion bar. The only difference was new Poly-loc motor mounts. I guess anything is possible when you tear something apart and put it back together.
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #678000
04/24/10 02:33 PM
04/24/10 02:33 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Schumacher makes a shim kit, EZ to install if you need a slight height adjustment for header clearance..
No need to start bending in the tubes..
Just my $0.01...
Re: TTi header touching passenger side torsion bar [Re: YGBSM] #678001
04/25/10 02:27 PM
04/25/10 02:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
No, they don't. The 4876311's exhaust port location is identical to a standard Stage VI, which means it's about .4" wider and .4" higher than an OEM head's exhaust port. That's why you have clearance issues w/ the torsion bar.
Re: TTi header touching passenger side torsion bar [Re: BradH] #678002
04/25/10 03:29 PM
04/25/10 03:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Measure your crankshaft centerline in relation to the K-frame etc just like they tell you in the directions. I have the locking Mighty mounts and they raise the engine slightly. My passenger side 2" TTi is close, so I wrapped the torsion bar with heat insulation.
Re: TTi header touching passenger side torsion bar [Re: BradH] #678003
04/25/10 05:29 PM
04/25/10 05:29 PM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Yes, I'm afraid you're right. My own fault for missing this, but the information sheet that came with the heads clearly says "exhaust ports are raised".
1968 Charger R/T
Re: TTi header touching passenger side torsion bar [Re: jbc426] #678004
04/25/10 05:54 PM
04/25/10 05:54 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yeah I would make sure the engine is sitting in there according to TTI specs. Chrysler was real sloppy on the k-frames back in the day so you don't know where that engine is until you measure.
