So whats a better choice Edelbrock or Holley carb #677938
04/23/10 06:20 AM
04/23/10 06:20 AM
MD
75dusted Offline OP
75dusted  Offline OP
MD
For my 318 motor what would be a better choice for a carb, Eddy 600 carb or the Holley Street Avenger 570 or 670 carb, motor consists of stock crank, rods, pistons, fully ported and polished 318 heads with larger intake and exhaust valves and a .020 mill on heads, Hughes Engines 318 whiplash cam, Edelbrock performer intake, 1 5/8 " headers full length , trans is a 727 with shift kit, rear 8 1/4 with 4.10 gears , all in a 74 Satellite, just a weekend cruiser to car shows and hangouts, so what do you reccomend on a carb
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677939
04/23/10 07:29 AM
04/23/10 07:29 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
might as well ask Ginger or Mary Ann, blondes or brunettes, chocolate or vanilla.....
I personally haven't had good luck with Holleys, so I run Edelbrocks on everything. For me, they are much easier to tune, and much more reliable. Your mileage may vary...
Re: So whats a better choice Edelbrock or Holley carb [Re: James74] #677940
04/23/10 08:00 AM
04/23/10 08:00 AM
scratchnfotraction Offline
I would drop the performer intake and go with a LD340/LD4B or RPM airgap
way better intake IMO
the LD4B will match the 318 head ports and works very good
I would go with a 750 holley carb
whiplash is
Re: So whats a better choice Edelbrock or Holley carb [Re: scratchnfotraction] #677941
04/23/10 08:16 AM
04/23/10 08:16 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I second the Holley 750.
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677942
04/23/10 08:18 AM
04/23/10 08:18 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677943
04/23/10 08:27 AM
04/23/10 08:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
holley. A good old fashion DP is all you need. Eddy's are ok for putting around in, but if it's going to see the track you'll need 2 to keep up w/ one holley.
Coming soon!!!!
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677944
04/23/10 08:53 AM
04/23/10 08:53 AM
NY usa
540challenger Offline
NY usa
I like both holley's and the eddies but i would go with the higher cfm carb 670 the other two will work great but must likily ruyn out of steam up top
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677945
04/23/10 08:59 AM
04/23/10 08:59 AM
crlush Offline
crlush  Offline
holley all the way.
Re: So whats a better choice Edelbrock or Holley carb [Re: crlush] #677946
04/23/10 09:30 AM
04/23/10 09:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
holley all the way.
,...the only good Edelbrock carb is the one that goes in the trash can on the first shot
Re: So whats a better choice Edelbrock or Holley carb [Re: DAYCLONA] #677947
04/23/10 09:34 AM
04/23/10 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
holley all the way.
Re: So whats a better choice Edelbrock or Holley carb [Re: Mr.Yuck] #677948
04/27/10 01:41 PM
04/27/10 01:41 PM
crlush Offline
crlush  Offline
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677949
04/27/10 02:10 PM
04/27/10 02:10 PM
AndyF Offline
AndyF  Offline
An Edelbrock 600 would work just fine on that motor. If it was me I'd probably go even smaller than 600 on that motor.
Re: So whats a better choice Edelbrock or Holley carb [Re: AndyF] #677950
04/27/10 02:25 PM
04/27/10 02:25 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Holley without question. For that motor and combination I would not go over 600CFM and keep it a vacuum secondary. Anything more than that is just wasted and is doing nothing for you.
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677951
04/27/10 02:52 PM
04/27/10 02:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'd go with the 3310 holley 750 vac worked way better on my 318 than a 600 holley or a 600 eddie.
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677952
04/27/10 06:30 PM
04/27/10 06:30 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
HOLLEY
Re: So whats a better choice Edelbrock or Holley carb [Re: DAYCLONA] #677953
04/27/10 10:52 PM
04/27/10 10:52 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
holley all the way.
YOU HAVE THE CARB BRANDS REVERSED in that statement, sorry!
Re: So whats a better choice Edelbrock or Holley carb [Re: volaredon] #677954
04/27/10 11:01 PM
04/27/10 11:01 PM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
I think holley's are just a pain to tune in. I like my edelbrock 600 on my sbc 350 in my malibu. If anything, a barry grant beats holleys night and day. On that setup, you do not need a DP holley if you decide to go with a holley. DP should only be used really on the track, vacuum secondaries if your going to be driving more on the street.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: So whats a better choice Edelbrock or Holley carb [Re: CurYellowBird] #677955
04/27/10 11:15 PM
04/27/10 11:15 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I won't be specific, but I see some pretty bad advice here.
brand is not as much the question as size, in my opinion. Both Holley and Eddy make a great 600 cfm carb, and either would be a great choice. I'd choose a holley #80570: 570cfm street avenger series. A mild street 318 will not need any more than that, and it will run way crisper with better throttle response than with a bigger carb. A 750 on this application is just a classic over-carb. Would the 750 work? sure. but it would be a pig down low. You've got a nice small street performance package, The right carb is one that is in line with that goal.
Re: So whats a better choice Edelbrock or Holley carb [Re: StealthWedge67] #677956
04/27/10 11:21 PM
04/27/10 11:21 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The OP said it was a street cruiser and a 74 Satellite (big car) with a 318.
The smaller (600) cfm carb is gonna give a whole lot better throttle response.
As for brand choice, it's a toss up as long as it's a new carb. Both have their good and bad points IMO.
Re: So whats a better choice Edelbrock or Holley carb [Re: 75dusted] #677957
04/27/10 11:31 PM
04/27/10 11:31 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I've run both on engines such as you describe...couldn't have been happier with either. Both are really good carbs.
Either are very tuneable...and can be made to get pretty good mileage.
First, DEFINITELY stick with a vacuum secondary...your satellite is a little on the heavy side, and the DP won't like heavy w/ a somewhat stockish torque converter...even though you've got decent rear gears.
I'd disagree that size is terribly important to an extent too...that's what's great about vacuum secondaries...too big a carb with vacuum secondaries, then the secondaries don't open all the way...only to what your engine is asking for.
That said, for a mild-ish 318, you can't beat a 600cfm. Heck, I used a 600 for a 360 that saw me into the lower 13's You'll get better mileage and throttle response with the appropriate sized carb.
In my opinion, you can probably tune an Eddy for better mileage than a holley, and you can probably tune a holley for better performance...but if you are hoping to avoid tuning, either is fine.
But since you are asking about the street avengers, you might be looking to tune at least a little, to which the holley is probably a bit easier for what you'll want to do. That said, eddy''s are pretty simple too.
Most who like one, stick with it...but myself, I'll go easily b/w each, no qualms about it. Heck, I've even been known to like a Quadrajet or two in my day lol.
To me, my guess is you'd probably be happiest with the holley street avenger 570. Check float level, set lean best idle, put in progressively lighter secondary springs until you get a hesitation/bog when flooring it, and then back up one spring size...and you're set. Easy, efficient, reliable and plenty quick.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
