e body wiring help needed #677396
04/22/10 03:44 PM
04/22/10 03:44 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, can anyone tell me what the dark blue wire on the plug coming down from the steering column is for? (70 challenger) I believe it is the third wire after the yellow and black wire. Mine just fried after the plug (dash side of plug) and I'm trying to figure out the cause. Thanks in advance OK I found out it is listed as ignition 1 in the SM. Where does this wire go?
Re: e body wiring help needed [Re: 440forPOWER] #677397
04/22/10 04:36 PM
04/22/10 04:36 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Ignition 1 - Start - Brown - 14 ga
Ignition 2 - Run - Dark Blue Wire - 18 ga
Ignition switch to:
Brake Warning Light
Key-In Buzzer
Terminal 23 on Firewall Connector
Engine Bay:
Alternator
Idle Solenoid
Regulator
Ballast Resistor
Car will probably start, but won't run.
Re: e body wiring help needed [Re: Snoopy] #677398
04/22/10 04:48 PM
04/22/10 04:48 PM
Lincoln NE
super gas
super gas
Lincoln NE
Thanks, the car starts and runs fine but the smoke rolling out from under the dash is a problem. All the insulation was burned off the dbl wire.
Re: e body wiring help needed [Re: 440forPOWER] #677399
04/22/10 04:50 PM
04/22/10 04:50 PM
Snoopy Offline
Snoopy  Offline
Check the engine bay wiring and the firewall connector.
