Hello, can anyone tell me what the dark blue wire on the plug coming down from the steering column is for? (70 challenger) I believe it is the third wire after the yellow and black wire. Mine just fried after the plug (dash side of plug) and I'm trying to figure out the cause. Thanks in advance OK I found out it is listed as ignition 1 in the SM. Where does this wire go?
