TIRE CLEARANCE IN THE 1/4'S #676796
04/21/10 09:09 PM
04/21/10 09:09 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
How much room do you need between the front of the rear tire and the 1/4 and the back of the rear tire and the 1/4?? Im NOT talking about the top of the wheel well just the front and back.
THANKS!!!
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676797
04/21/10 09:17 PM
04/21/10 09:17 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
with a slick i wouls say 1 inch but my drag radial has about 3/4" on the front of the tire.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676798
04/21/10 09:20 PM
04/21/10 09:20 PM
gregsdart Offline
gregsdart  Offline
I have one tight spot in the front, 3/4 inch. My guess is if you have 3/4 plus, you will be OK. Better if you have 1 inch.
What type tires you running? Rims?
Re: TIRE CLEARANCE IN THE 1/4'S [Re: gregsdart] #676799
04/21/10 10:52 PM
04/21/10 10:52 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Drag radials, 5/8th inch clearance and it does not touch at 125 mph..
Re: TIRE CLEARANCE IN THE 1/4'S [Re: gregsdart] #676800
04/21/10 11:07 PM
04/21/10 11:07 PM
Im running 28x11.5 QTP's and want to move up to 29x11.5 QTP's. I measured it today,I have 1 1/2" in the front and 1 5/8" in the back of the 1/4.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: Jeepmon] #676801
04/21/10 11:08 PM
04/21/10 11:08 PM
Hey Jeepmon...What do you have for leaf springs?? Ill be putting in SS springs this summer.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676802
04/21/10 11:13 PM
04/21/10 11:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Mike...what are you up to.......fwiw I would look at mono leafs and cal tracs.....
Re: TIRE CLEARANCE IN THE 1/4'S [Re: joshking440] #676803
04/21/10 11:14 PM
04/21/10 11:14 PM
I dont have the funds for cal-tracs and monos.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676804
04/21/10 11:19 PM
04/21/10 11:19 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
well, I have a buddy...who has stock springs and cal-tracs in an a-body going 9.45 on the bumper......truth is Mike, i have had a pic of your car as a background on about 7 different computers and have always love the stance....dont change....
Re: TIRE CLEARANCE IN THE 1/4'S [Re: joshking440] #676805
04/21/10 11:35 PM
04/21/10 11:35 PM
WOW!!!!!,,,Im HONORED!!!!! I dont see my car as special but THANKS!!!!
The truth is my stock springs now are SHOT!!!! Their broke and twisted so I NEED springs. Someone offered me a set of SS springs for a REALLY good deal!!! I dont know if I can turn down the deal.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676806
04/22/10 01:33 AM
04/22/10 01:33 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Cal-Trax and very old/worn old stock springs..
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676807
04/22/10 06:20 AM
04/22/10 06:20 AM
412 SB Duster Offline
At 1/2 inch in the front i think you will have issues. i would move them back so they are centered in the wheel well.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: 412 SB Duster] #676808
04/22/10 06:54 AM
04/22/10 06:54 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Assuming that the relative difference in diameter is accurate(and it might not be), that would leave 1" at the front and 1 1/8" at the back. No problem unless your rim width is way to narrow. Also keep in mind that the spring change "might" relocate the rearend slightly.
If your worried about it then just bend the flanges slightly so that if the tire hits it won't hit a sharp edge.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: GomangoCuda] #676809
04/22/10 08:28 PM
04/22/10 08:28 PM
I wish I had bought 10" rims instead of 8" rims.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676810
04/22/10 08:58 PM
04/22/10 08:58 PM
Are the QTP bias or radial tires? Either way the 29 inch tire should be 1/2 taller on the top and bottom, front and rear of them so you should have more than enough room for the taller 29 inch tires, Unless the car runs 140+MPH now and thier bias ply tires
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676811
04/22/10 09:11 PM
04/22/10 09:11 PM
pa
catman408 Offline
catman408  Offline
pa
Do you have your springs moved in. i have a buddy that i bought him 27 x 11.5 HOOSIER QTP AND HE THINKS THEY WILL HIT THE SPINGS. HAS BEEN RUNNING 27 X 10.5 NO PROBLEM.
1989 lebaron 408 B1BA 5.969 1/8@ 116.16 9.393 1/4 @ 148.83 New motor 426 w8 5.683 @122.49 1/8 8.88 @153.49 1/4
Re: TIRE CLEARANCE IN THE 1/4'S [Re: Cab_Burge] #676812
04/23/10 12:48 PM
04/23/10 12:48 PM
1st..My car will NEVER go 140+mph!!!!
2nd.. They are the QTP's street slick,not radial.
3rd.. THANKS!!!!
Re: TIRE CLEARANCE IN THE 1/4'S [Re: catman408] #676813
04/23/10 01:06 PM
04/23/10 01:06 PM
I have 15x8 rims with 4.5bs and 28x11.5 QTP's. I also have stock leafs in the stock location. My tires DID rub a little on the springs so I put on 1" wheel spacers and that took care of the problem.
I do feel if I had gone with a 10" rim,the tires would not have bulged out and hit the leafs.
Im not sure if the back space would make a difference.Maybe someone can chime in with some info.
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676814
04/23/10 10:20 PM
04/23/10 10:20 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
If feesable, switch to 10" rims
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: TIRE CLEARANCE IN THE 1/4'S [Re: MIKES_DUSTER] #676815
04/24/10 10:29 AM
04/24/10 10:29 AM
NC
440Jim Offline
440Jim  Offline
NC
I think front to back you will be fine. Once you reach 3/4" things get tighter. Rim width to tire width, mph, tire construction, etc.
I know cost is high, but the time to switch to a 10" wide rim with the appropriate back spacing is when changing tires. After you run the new rims/tires and have no problems, you can sell the old rims to offset some of the cost. I see those tires are really 10" wide tread.
