Re: TIRE CLEARANCE IN THE 1/4'S
[Re: gregsdart]
#676800
04/21/10 11:07 PM
04/21/10 11:07 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
I have one tight spot in the front, 3/4 inch. My guess is if you have 3/4 plus, you will be OK. Better if you have 1 inch. What type tires you running? Rims?
Im running 28x11.5 QTP's and want to move up to 29x11.5 QTP's. I measured it today,I have 1 1/2" in the front and 1 5/8" in the back of the 1/4.
[Re: joshking440]
#676805
04/21/10 11:35 PM
04/21/10 11:35 PM
MIKES_DUSTER
well, I have a buddy...who has stock springs and cal-tracs in an a-body going 9.45 on the bumper......truth is Mike, i have had a pic of your car as a background on about 7 different computers and have always love the stance....dont change....
WOW!!!!!,,,Im HONORED!!!!! I dont see my car as special but THANKS!!!!
The truth is my stock springs now are SHOT!!!! Their broke and twisted so I NEED springs. Someone offered me a set of SS springs for a REALLY good deal!!! I dont know if I can turn down the deal.
[Re: MIKES_DUSTER]
#676806
04/22/10 01:33 AM
04/22/10 01:33 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Hey Jeepmon...What do you have for leaf springs?? Ill be putting in SS springs this summer.
Cal-Trax and very old/worn old stock springs..
[Re: 412 SB Duster]
#676808
04/22/10 06:54 AM
04/22/10 06:54 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Assuming that the relative difference in diameter is accurate(and it might not be), that would leave 1" at the front and 1 1/8" at the back. No problem unless your rim width is way to narrow. Also keep in mind that the spring change "might" relocate the rearend slightly.
If your worried about it then just bend the flanges slightly so that if the tire hits it won't hit a sharp edge.
[Re: MIKES_DUSTER]
#676811
04/22/10 09:11 PM
04/22/10 09:11 PM
Posts: 39 pa
catman408
pa
Do you have your springs moved in. i have a buddy that i bought him 27 x 11.5 HOOSIER QTP AND HE THINKS THEY WILL HIT THE SPINGS. HAS BEEN RUNNING 27 X 10.5 NO PROBLEM.
1989 lebaron 408 B1BA 5.969 1/8@ 116.16 9.393 1/4 @ 148.83
New motor 426 w8 5.683 @122.49 1/8 8.88 @153.49 1/4
[Re: Cab_Burge]
#676812
04/23/10 12:48 PM
04/23/10 12:48 PM
MIKES_DUSTER
Are the QTP bias or radial tires? Either way the 29 inch tire should be 1/2 taller on the top and bottom, front and rear of them so you should have more than enough room for the taller 29 inch tires, Unless the car runs 140+MPH now and thier bias ply tires
1st..My car will NEVER go 140+mph!!!! 2nd.. They are the QTP's street slick,not radial. 3rd.. THANKS!!!!
[Re: catman408]
#676813
04/23/10 01:06 PM
04/23/10 01:06 PM
MIKES_DUSTER
I have 15x8 rims with 4.5bs and 28x11.5 QTP's. I also have stock leafs in the stock location. My tires DID rub a little on the springs so I put on 1" wheel spacers and that took care of the problem. I do feel if I had gone with a 10" rim,the tires would not have bulged out and hit the leafs.
Im not sure if the back space would make a difference.Maybe someone can chime in with some info.
[Re: MIKES_DUSTER]
#676815
04/24/10 10:29 AM
04/24/10 10:29 AM
Posts: 16,928 NC
440Jim
NC
I think front to back you will be fine. Once you reach 3/4" things get tighter. Rim width to tire width, mph, tire construction, etc.
I know cost is high, but the time to switch to a 10" wide rim with the appropriate back spacing is when changing tires. After you run the new rims/tires and have no problems, you can sell the old rims to offset some of the cost. I see those tires are really 10" wide tread.
